Heavy Clutch pedal ...
[Closed] Heavy Clutch pedal ? ...
3 Users
Ive got a 04 plate Nissan primera diesel and the clutch is very heavy with a very low biting point, is this a sign that the clutch is on the way out ??
Always been aware that the clutch is heavy , but ive had a hire car this week while the turbo was been replaced and the clutch was alot nicer to use than mine ..
Posted : 11/09/2010 2:51 pm
Probably is worn out
Posted : 11/09/2010 3:04 pm
Could be a worn clutch cable,( if it's not hydraulic) if the clutch is worn the bite point normally goes up( top of pedal) not lower
Posted : 11/09/2010 3:13 pm
khani - Member
Thats my thinking, ive had clutches go and slip before but the bites always come higher not lower ??
Posted : 11/09/2010 3:16 pm
The only time I've seen a clutch go lower is when the cable has stretched or worn and not pulling the arm fully
Posted : 11/09/2010 3:20 pm
Just looked at the manual and its hydraulic not cable , may need a bleed im thinking ?
Posted : 11/09/2010 3:25 pm
I had an old Nissan bluebird and it did what you describe, heavy and lower bite point and it was a streched and worn cable dragging and not pulling all the way,
EDIT no idea on hydraulic, sorry
Posted : 11/09/2010 3:26 pm
