I have just bought one.
I also have memory map software. Anybody know how to make the memory-map map appear as the map you look at on the gps (rather than the rubbish one it comes with)? I cant find it in the instructions.
I have put the map on an SD card & its in the units ...but there must be a away of making the GPS read it.
Ta in advance
I seem to recall that you can't.
Sorry, old bean.
You can only use Garmin TOPO maps or Citymaps.
Ar5e. Cue grumpy face for an hour or two
Go and look at how much the Garmin maps are and have a grumpy face for the rest of the afternoon :-p
Yeh, pants 🙁
The roady ones arent too bad & as I live in the South I can never get more than about a mile from a road, so they may have to do.
£149.99 thats too much... far far too much
You can get them cheaper than that (much cheaper if you look hard enough). Don't bother with the Topo, it's shite. Also, do your route planning on Bike Route Toaster(or MM and export as a GPX).
Sorry to tell you, the unit is next to uaseless with just the base map installed.
Bob
you can get the topo maps from *ahem* other sources
if you insist on buying maps though, tracklogs is now compatible with the 6/705
you may need to download the beta version though
Hmmm, head off to look for *ahem" sources
Cheers 😆
cant find any 'ahem' maps that work.
Something to do with unlock codes ?
S
you'll need to look further for an unlock code generator (I assume)....
Boblo
Give us a clue.
I bought the Garmin TOPO for the south (Edge 705), does the job .. just
Want a pc mapping software or the street map.
Help
email address please.
Bob
Boblo.
Mail addy
sngooch(at)gmail.com
The Topo maps are better than nothing off-road, they show contours, ground cover and paths, but it doesn't differentiate between footpaths, bridleways and any other type of path.
Boblo
mine is geoff(at)imnotthealien.co.uk
I have memory map but not garmin stuff
