Gaggia descaling
[Closed] Gaggia descaling
8 Users
Any particular stuff I should use - is one brand better than the others?
Posted : 31/01/2009 11:04 am
Gaggia do their own stuff in little sachets.
No idea if it's better than others.
Posted : 31/01/2009 12:05 pm
Happydonkey.co.uk will sell you all the stuff you need, including puly caff and a blind basket for backflushing. All that backflushing sounds rubbish to me though.
But I just take the opportunity of taking off the shower plate and the shower block (just undo the 2 allen bolts and prise it off) and de-gunking it all manually, and running ordinary descaler through.
Last time I left it so long that bits of scale dislodged and got stuck in the works, but poking about with a cocktail stick sorted it.
I just bought a new rubber seal, shower screen and cleaning brush from happy donkey - well worth it.
Posted : 31/01/2009 1:28 pm
I use the Gaggia stuff about once every six months. As we live in a hard water area we have a Breville kettle that has the Brita water softening system built in. I always fill the Gaggia using water that's been through the kettle filter to avoid scaling up the Gaggia.
Posted : 31/01/2009 5:37 pm
eekk.. hard water area too. not descaled in 2 years :s
Posted : 31/01/2009 5:50 pm
I heard once that there is a coating on the boiler that is damaged by most descalers - so go for the Gaggia one. No idea if the claim was true - I've always put filtered water in so never descaled mine.
Posted : 31/01/2009 5:51 pm
soft Scottish water, no need to de scale here 🙂
Posted : 31/01/2009 6:28 pm
Filtered water. Now that makes sense. I'll descale then look into getting some Gaggia descaler.
Muchos gracias.
Posted : 02/02/2009 11:00 pm
puly caff works for me, mind you I live in T' north so soft water here
Posted : 02/02/2009 11:13 pm
But do what bigjohn said as well - take off the plate and the stuff behind it. All the sticky oils in the coffee make a residue that is nothing to do with whether the water is hard or not and the descaler does not touch it. It's very simple but if I remember correctly there are good instructions on the Gaggia website
Posted : 03/02/2009 10:11 am
