Front door lock, wh...
[Closed] Front door lock, which one?
9 Users
OK, I know some people who believe that youtube doesn't exist will think this controversial, but given that there are tutorials for picking/bumping/snapping virtually every kind of euro-lock on the market, I would like to ask which is the best lock available if you would like to avoid being laid open to every crack addict that fancies having a go at raiding your home?
Obviously some won't have the honed skills of the crack addicts on youtube, but some might have half a clue...
Cheers in advance.
Posted : 12/05/2011 9:19 pm
British standard mortice sash lock, era, or yale or union, long screws, and a set of handles.
also fit a dead lock further down the door for extra security.
A steel reinforcing bar down the inside of the frame also helps.
Posted : 12/05/2011 9:23 pm
Whatever your insurance company recommends - don't fit something they recommend and, no matter how good it may be, they will wriggle out of any claim.
Posted : 12/05/2011 9:29 pm
Thank's, been looking at ABS & Cisa, cisa is about 30% cheaper & seems better specced, it looks like modern euro-locks are quite a target nowadays 🙁
Cheers.
Posted : 12/05/2011 9:32 pm
I have a set of "bump key's" and they're the most overrated things I've found.
I bought a set from my locksmithing supplier and was so dissapointed.
The shite they spout about bumping any euro/rim cylinder lock is guff, trust me. That's not to say that you don't need a descent bs mortice deadlock to back your nightlatch up.
There are plenty easier wasy to open doors than "bumping" a lock.
As you may have guessed, I'm a locksmith.
Cisa are pretty decent
Posted : 12/05/2011 9:33 pm
mastiles_fanylion - Member
M-F, conflicting advice?
PS, thanks to the others, especially FF who gives a great insight, cheers.
Posted : 12/05/2011 9:36 pm
He means if it's not recommended by them
Posted : 12/05/2011 9:40 pm
nah, just poor style:
(fit) Whatever your insurance company recommends - (if you) don't fit something they recommend (then), no matter how good it may be, they will wriggle out of any claim.
Posted : 12/05/2011 9:43 pm
 Taff
Check Secured by Design website - will give you a good list of security approved locks.
Posted : 12/05/2011 9:46 pm
Also ensure the door construction is strong seen a few doors easily defeated by a good kick,in the right place.
Alos check the frame for adequate fixings.
Posted : 12/05/2011 9:51 pm
I replaced our euro locks with CISA ones, when I looked into it they seemed the best security for the money. I did spend a bit of time investigating as we had just been broken into (luckily only the two cars taken...) and I was slightly paranoid about security.
The scary thing is I replaced one of the euro locks on a set of sliding doors in the house. I didn't have the key for it so had to break it out - worrying easy to open when you know how.
Posted : 12/05/2011 9:53 pm
FWIW We've been broken into recently and relying on locks alone isn't enough, even high quality locks can be broken out of a door by the use of screwdrivers, so an alarm and active neighbours are also required....
Posted : 12/05/2011 10:17 pm
Thanks all, ordered a couple of Cisa S types.
Cheers.
Posted : 13/05/2011 7:01 am
Yes I meant if you don't fit a recommended lock - I can see how English my confusing was though.
Posted : 13/05/2011 8:11 am
