Free and easy to us...
[Closed] Free and easy to use cad program??
18 Users
Morning,
I am after a cad program to input my knife designs and leatherwork designs into so I can get some templates laser cut.... what is out there that is good, FREE and easy to use?
Posted : 02/12/2016 7:42 am
Google sketch up is good for beginners. Lots of support, too. Draftsight is a bit more technical. Probably harder to learn but might work out better for getting the laser cut files out. Both free
Posted : 02/12/2016 7:54 am
Easy to use [url= http://hackaday.com/2015/08/09/cardboard-aided-design-is-the-new-cad/ ]C.A.D[/url] package. 😉
Posted : 02/12/2016 7:59 am
[url= http://uk.rs-online.com/web/generalDisplay.html?id=designspark/designspark-mechanical ]This[/url] looks the bee's knees.
Posted : 02/12/2016 8:01 am
Stato... that's my CURRENT cad package... needs upgrading....
Posted : 02/12/2016 8:27 am
2D? http://librecad.org/cms/home.html
very easy to learn
Posted : 02/12/2016 9:40 am
Draftsight. It's free and easy to get started, plus it doesn't use stupid proprietary file types and can open loads of different things.
Posted : 02/12/2016 9:49 am
AutoDesk Fusion 360 is Free for hobbyists. Easy to use and hundreds of videos/tutorials.
Posted : 02/12/2016 10:01 am
Draftsight for 2D or Onshape for 3D
DO NOT use SketchUp it's [u]not[/u] CAD whatever they say. Awful, awful application.
Posted : 02/12/2016 10:02 am
Second for Onshape. Crazy high solidworks pricing structure means we have been testing it out at work recently with a mind on switching completely in the future.
Posted : 02/12/2016 10:17 am
+1 for Draftsight.
Posted : 02/12/2016 10:41 am
Qubism on Android.
Great fun 🙂
Posted : 02/12/2016 10:44 am
 moff
+1 Draftsight (2D) - perfect for generating .dxf files for laser/waterjet cutting
+1 Fusion 360 (3D) - direct output for 3D printing
Posted : 02/12/2016 11:17 am
Thanks chaps.... will have a look later...
Posted : 02/12/2016 11:31 am
freecad
Posted : 02/12/2016 12:37 pm
The draftsight workflow (keyboard commands etc) is very similar to AutoCAD so if you use that ine you are picking up AutoCAD skills too.
Posted : 02/12/2016 12:44 pm
 tiim
AutoDesk Fusion 360
This.
For work, I used solidworks for 10 years and solidedge for 5. I now do most CAD in Autodesk Fusion 360 covering parts, assemblies and drawings. I've used the outputs for laser cutting directly as well as fabrication and manufacturing by sub cons.
It's also being updated quite frequently and I've had good success when raising issues.
Posted : 02/12/2016 12:45 pm
DO NOT use SketchUp it's not CAD whatever they say. Awful, awful application.
Its great at what it is, but it is what it is. If you're non-cad trained then its pretty intuitive to use, if you are CAD savvy (or even just vector graphics savvy) its seems totally un-intuitive because your intuition is based on those conventions.
sketch up is easy to use but can take a fair bit of fannying to get from model you draw to the file a CNC machine will play with
I draft up my sculptures in sketch up (just because its what I've always used) but I need to keep an old version of sketchup 7 running - export my models to that in order to use a plugin that only works with that version to export individual faces as SVG files which then need tidying in inkscape to be ready to pass on to sheet cam then then into my plasma cutter
Keeps me busy
So does repeatedly trying to select a tiny dot to delete it before realising its a bit of dirt on the screen.
Posted : 02/12/2016 2:12 pm
Fusion 360. It's a proper thing and there's tons of stuff on youtube
Posted : 02/12/2016 2:18 pm
The thing is I am a total novice so need something that is fairly intuative but more in depth than paint!
Posted : 02/12/2016 2:42 pm
This guy does some good videos to explain stuff
Posted : 02/12/2016 4:09 pm
