Filter Tap - replac...
[Closed] Filter Tap - replacment filters
2 Users
We have a filter tap that takes the generic cartridge type filters with 6mm push fit fittings on both ends.
Anybody got any expereince of buying from a particular place and also the spec people choose to go with.
Posted : 27/04/2011 8:34 am
It is probably only a carbon filter to de-taste the water, so most any generic one will give you the same results.
Posted : 27/04/2011 8:37 am
If that is the case "Too Tall" then what level of filtration should I look at as the normal water tastes fine.
Posted : 27/04/2011 8:38 am
