Excel help please
Excel help please
5 Users
I have an Excel sheet containing thousands of rows. Each row has a start value in column A and an end value in column B. I need to generate all the unique values in the range.
For example, for start value = 1000 and end value equals 1199 I need to generate all then numbers between 1000 and 1199 inclusive. For start value = 1 and end value = 5 it'd be 1, 2, 3, 4, 5
I can't find a decent way to do it in Excel - any ideas?
Posted : 02/07/2022 5:26 pm
VBA?
When you say 'generate,' what do you mean? What are you going to do with 200 values from a single row, write one per cell? Stick them all in one huge one? Something else?
Posted : 02/07/2022 5:33 pm
And I suppose the other question is, why?
Is whatever you're trying to achieve not better approached by whatever the Excel equivalent is of a FOR... DO loop using A and B as endpoints? FOR f=A to B; DO [thing] with f; NEXT f.
Posted : 02/07/2022 5:36 pm
It's a list of obsolete terminal id ranges. It will be the input for a mainframe program that expects one value per line - it'll then delete that terminal record.
VBA would work or exporting it as a CSV and writing a perl, python, java or javascript program
Posted : 02/07/2022 5:44 pm
Right. I think I'd concur then that the approach I'd be investigating there would be to save the spreadsheet as a CSV and then iterate through it with a bash script.
Hang on while I phone a friend.
Posted : 02/07/2022 5:55 pm
This is what said friend came back with.
#!/bin/bash
infile="$1"
OIFS=$IFS
IFS=","
if [ -z "$infile" ]; then echo "Syntax: $0 infile"; exit 1; fi
if [ ! -f "$infile" ]; then echo "Filename $infile does not exist."; exit 1; fi
while read rangestart rangeend; do
        seq $rangestart $rangeend
done < $infile
IFS=$OIFS
"sends to STDOUT, pipe to whatever file"
Posted : 02/07/2022 6:43 pm
whats the biggest range?
firt colum to the right concatenate everything to the right ,
next column =start value
next column something like =if(cell to left-end value>0,","&cell to the left+1,"")
sprinkle som $ in to lock the start end vlaues, then drag it acrosss however many columns are needed
you concantenated column should be sorted
thats top of my head stuff that.
Posted : 02/07/2022 7:08 pm
Thanks both, just knocked up some shonky VBA that works
Dim tid, startValue, endValue As Integer
Dim inputRows, currentRow, nextRow As Long
Sub TidGenerate()
inputRows = Worksheets("Sheet1").Cells.Find("*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
For currentRow = 1 To inputRows
startValue = Worksheets("Sheet1").Cells(currentRow, 1).Value
endValue = Worksheets("Sheet1").Cells(currentRow, 2).Value
For tid = startValue To endValue
nextRow = Worksheets("Output").Cells.Find("*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row + 1
Worksheets("Output").Cells(nextRow, 1).Value = tid
Next tid
Next currentRow
End Sub
Posted : 02/07/2022 7:16 pm
I suspect you could just have done nextRow = nextRow + 1 but looks ok
Posted : 02/07/2022 7:21 pm
where do the numbers have to go?
In your example above, if you have a start value of 1 in cell A1, and an end value of 5 in cell B1, then which cells do you want the numbers 1,2,3,4, and 5?
Posted : 04/07/2022 9:59 am
