Excel Help
[Closed] Excel Help
10 Users
Need to remove a trailing semicolon from cells of varying lengths.
It will not always be present.
So would only need to be removed on the bottom of these two rows
Account group default (all); BI001816 D; XPTUAG557
Account group default (all); XXXY (XXXY123);
Any suggestions on the easiest way.
Thanks
Posted : 16/11/2016 3:26 pm
data > text to columns. use semi-colon as a delimiter.
Posted : 16/11/2016 3:27 pm
Did think about that but number of semi colons in cell varies
Posted : 16/11/2016 3:29 pm
Won't that explode if there's other semi-colons elsewhere in the cell?
Export as CSV but use a character that doesn't appear in the cells as the separator, lets assume it's the comma.
Run sed "s/;,/,/" filename.csv > new_filename.csv
Import file back into Excel.
Posted : 16/11/2016 3:36 pm
Formula along the lines of...
=REPLACE(A1,LEN(A1),RIGHT(A1)=";","")
Posted : 16/11/2016 3:38 pm
Define existing data as a table.
Create a new table in another sheet with the source as an SQL query.
Query is:
Select other fields ,
replace(old_table_element,";"," "), other fields from old_table
Edit: or just use the replace function in Excel (didn't know that existed).
Posted : 16/11/2016 3:41 pm
=IF(RIGHT(A1,1)=";",(LEFT(A1,LEN(A1)-1)),A1)
Posted : 16/11/2016 3:47 pm
Hit Alt+F11
Click on Sheet1(Sheet1) and in RHS window type
Option Explicit
Public Sub CleanCells()
Dim Row As Integer
For Row = Sheet1.UsedRange.Rows(1).Row To Sheet1.UsedRange.Rows(1).Row + Sheet1.UsedRange.Rows.Count
Dim Cell As Range
For Each Cell In UsedRange.Rows(Row).Cells
If Right(Cells(Row, Cell.Column), 1) = ";" Then
Cells(Row, Cell.Column) = Left(Cells(Row, Cell.Column), Len(Cells(Row, Cell.Column)) - 1)
End If
Next Cell
Next Row
MsgBox ("All done")
End Sub
Hit CTRL+G
In the Immediate box at the bottom, type
call sheet1.CleanCells
It will remove any trailing semi-colons from all cells in Sheet1
Posted : 16/11/2016 4:05 pm
Works but there appear to be random trailing spaces which throw it out.
Will use TRIM to tidy it up.
Thanks all
Posted : 16/11/2016 4:08 pm
Why not just use find and replace?
Posted : 16/11/2016 4:11 pm
Can't specify only trailing characters (that I know of). I just use VBA for everything.
Posted : 16/11/2016 4:13 pm
what Doug said
Posted : 16/11/2016 4:15 pm
