Excel for begineers
[Closed] Excel for begineers
7 Users
Some help from the hive if possible please!?
I have a list of dates with corresponding values. sometimes there are a number of entries on the same date with different values (maybe 20-30 entries). I want to know the sum and average of the values based on each date. I was going to give the spreadsheet to our receptionist and leave her for a day or so to do this by hand, but there must be an easier way in excel. Lookup and sum or lookup and average.
Posted : 20/02/2017 12:54 pm
SUMIF and COUNTIF are the basic tools you can use. Have a practice and you should be able to work it out v quickly.
For more advanced users SUMPRODUCT would be a slicker solution.
Posted : 20/02/2017 1:00 pm
Simple(ish) long hand way would be countif
Copy all your dates to somewhere else (make sure they are date format with no time) paste & remove duplicates
Paste the new list into a row above the other list (Paste Special Transpose)
So they now sit in Row 1, Dates in Row 2 Col A, Values Row 2 Col B
Under each date eg C2=IF(C$2=$A2,B2,"")
Drag that down then across each row then either on that sheet or elsewhere SUM(C2:CNumber) or Avg
sure there is a simpler way
Posted : 20/02/2017 1:01 pm
perfect, Stoners solution is within my brain power and works a treat, Thanks
Posted : 20/02/2017 1:09 pm
Pivot table seconded
Posted : 20/02/2017 1:12 pm
those pivot tables look like a good idea for next time.. 😀
Posted : 20/02/2017 1:18 pm
Please use a pivot table. they are perfect for what you want.
Its dead easy to summarise by
count
sum
average
max
min
here is an example:
[url= https://dl.dropboxusercontent.com/u/438710/pivttableexample.xlsx ]https://dl.dropboxusercontent.com/u/438710/pivttableexample.xlsx[/url]
Posted : 20/02/2017 1:34 pm
@sum( . )
HTHs.
Posted : 20/02/2017 1:56 pm
