Electronics. What i...
[Closed] Electronics. What is it that I'm after?
I want a battery powered (say 9v PP3), standalone, timer controlled relay that can close a 24v circuit.
It would be great to have the ability to program the timer with a number of programs as well as a boost
I guess the alternative is something that runs from the Mains:
http://www.ebay.co.uk/itm/180857386690
Ive got an immersion heater timer but its not a relay. I guess I could just add a 240v relay to it? Just need to stick it in a surface mounted box I guess?
Posted : 28/11/2012 3:13 pm
Any basic timer unit can be converted to switch mains via a Relay, just make sure the relay includes a diode across the low voltage contacts to stop reverse EMF stuffing up the controller (most have the diode integrated).
Posted : 28/11/2012 3:23 pm
What about something like this:
http://www.quasarelectronics.co.uk/ci0052-weekly-programmable-timer-relay-module.htm
Posted : 28/11/2012 3:25 pm
ยฃ87.46
comedian, footflaps! ๐Ÿ˜‰
Got a link (ebay?) to a suitable relay for me ff? Can I expect the diode to be inside one?
Posted : 28/11/2012 3:29 pm
[url= http://www.maplin.co.uk/5a-miniature-relay-37515 ]Maplin p/n N13AW[/url] relay (DPDT, 240v coil). I guess that it would be the 8 pin base that you'd need.
Use that along with your timer that you already have - you should really enclose it so that you've not got the 240v terms exposed.
No snubbing diode req across the coil as its an AC coil - a snubbing diode would act as a half wave rectifier (ish) and probably stop the relay picking reliably.
Posted : 28/11/2012 3:40 pm
thanks mrjmt. I think that's the cheapest way forward.
Yep, Id get a surface box for it.
Ive done similar with a two relay underfloorheating control.
Posted : 28/11/2012 3:46 pm
Sounds like the perfect excuse to buy an Arduino.
Posted : 28/11/2012 3:49 pm
Many times Ive thought arduino or raspberry pi (thanks to Make mag & boing-boing), but who am I kidding. I have trouble with Microsoft Word let alone trying to learn to program something ๐Ÿ˜ณ
Posted : 28/11/2012 3:50 pm
Didn't notice the price! That is a little steep....
Posted : 28/11/2012 3:58 pm
BTW mrjmt, although I only need SPST I think, I assume that I might as well get a DPDT as they are more easily available and can be used just the same?
Posted : 28/11/2012 4:07 pm
aye, just use one set of contacts. it just means you can isolate pos and neg if you really fancy it!
Posted : 28/11/2012 5:04 pm
 juan
Intersting installation, using both copper and composite.
Posted : 28/11/2012 5:12 pm
