electronics and sol...
[Closed] electronics and soldering expert help needed please.
I have some electronic equipment with a 5pin Lemo female connector (0B) that needs replacing.. it is the charger socket for the thing (surveying kit)
anyone in the Manchester area willing to help please?
happy to pay of course.
Posted : 09/10/2014 8:10 am
I'm in Bradford - when do you need it done?
Can you access it, or does the machine need opening first?
I suggest you save me as a last resort as I don't have a very small soldering iron. I can do it but if someone's got a temperature-controlled one they'd do a better job.
This was yesterday with a temp controlled one. And I have the technique better after doing about 20 of the 25 I figured how I [i]should[/i] have been doing it!
My fee is 4x Badger Ales in bottles ๐Ÿ™‚
Posted : 09/10/2014 8:21 am
 Del
I'm nowhere near you so can't really help, but lemo sockets tend to be pretty robust. why do you think it needs replacing?
Posted : 09/10/2014 8:49 am
One of the pins out the charging plug is stuck in the lemo so we can't charge it any more hence the replacement.
Posted : 09/10/2014 8:54 am
Can you post it? I have the skills and tools but I'm in Bristol.
Posted : 09/10/2014 12:14 pm
I could do, I'm getting it back tomorrow. Will remove the board and box it up.
Do you have lemo connectors? Or can you source them once you see the offending one?
Obviously I'm paying.
Posted : 09/10/2014 8:07 pm
Gofasterstripes, I'm in Leeds tomorrow, can I pop by Bradford to show you the offending Lemo?
Posted : 09/10/2014 9:02 pm
Wrong about the Lemo, I think it's a Fischer DBEU 102 A054
Posted : 09/10/2014 10:26 pm
Hi, I'll be in between 5 and 8pm. I don't have the connection you need here. Can you source the part?
Posted : 09/10/2014 11:51 pm
Hoping to get one from Leeds later.
Posted : 10/10/2014 5:31 am
Hi, it look like you have a closer offer, this will probally be best for you and the lack of postage. However if your still stuck give me a shout, I'll look up the connector type today just see what's involved.
Posted : 10/10/2014 6:09 am
Thanks cycle biker, can you email me your email address please, just in case.
Component has 5 pins that go through the PCB and get soldered in, component then is a bulkhead through the face plate of the kit (topcon hiper pro base and rover)
Posted : 10/10/2014 8:10 am
Okay - This seems possible, though the socket is tiny isn't it?
I'll try to borrow an electric iron today, but either way email me and we'll have a good look at it.
If I can't borrow an iron and it's too small to be done with my existing iron then I'll be happy to do it if you pay for a small electric iron.
http://www.maplin.co.uk/p/antex-30w-soldering-iron-includes-stand-n11by
Maplin is just up the road, so we can go and choose a cheap small iron, perhaps the above.
I'll keep that instead of the beer, that would also be fine ๐Ÿ™‚
Email me, sam{d0t}firth{?t}gmail{d0t}com, anytime today, but I'll be at work in town 'till 5.
I live on Canal Road, close to Forster square station, I suggest you arrive around 5:30 and you should be able to park near my place. By all accounts Bradford traffic is hell, but I hope by then on a Friday it'll have calmed down a bit.
See you later?
Sam
Posted : 10/10/2014 8:15 am
Right, thanks firstly for the offers of help, I got my survey gear back, got the new part, slightly different in that the screw thread will be on the inside of the face. Of the outside but other than that...
Problem is the gap between the pins and the circuit board is small, my hope was to cut the pins to set the damaged Fischer connector free and solder new wires on (3) then to the new connector which will provide a bit of welcome leeway either way.
I was trying to avoid actual soldering of the PCB personally. Also, the gap to get to the back of the pins is fairly narrow, awkward only, not impossible but not a job I'd like to tackle myself. (I was going to have a go if the wire option was a goer.)
So, gofaster, cyclebiker, still able to help?
I can strip it and take some photos if you like but email addresses might be more appropriate for that.
Posted : 10/10/2014 5:25 pm
YGM
Posted : 10/10/2014 6:39 pm
Ditto YGM
Posted : 10/10/2014 9:46 pm
Hahah, what a helpful forum!
Posted : 10/10/2014 9:47 pm
From your other email gofaster I guess you did not meet up today.
Posted : 10/10/2014 9:53 pm
No cyclebiker, I couldn't get there at that time. Shame as I was in Bradford at lunchtime too?
Posted : 10/10/2014 9:59 pm
Oh well, send over some picks and I'll see what I think.
Posted : 10/10/2014 10:04 pm
