electrical socket c...
[Closed] electrical socket checker tool ?
we have a problem in 10 yrs old house with tripping RCD circuits. Can't trace by trial and error/ events and a guy at work suggested a tool you can get in B&Q that plugs into a socket and tells wether it's wired up right.
Can anyone point me in right derection ? electrical luddite here!
Posted : 26/03/2013 12:49 pm
45 quid mind you.
by cant trace by trial and error you have unplugged EVERYTHING on the ring thats tripping and plugged one item in at a time.... if it was all grand and suddenly started crapping it its highly likely its an appliance crapped out.
Posted : 26/03/2013 12:56 pm
trail rat, thanks - its been doing it intermittently for years - seems worse in winter, but no pattern - can do it when we are lying in bed and all appliances off. Might try taking the faceplates off and checking for loose earths
Posted : 26/03/2013 1:16 pm
you can get one for about a tenner. I use it for a double check if I've put everything back right and nothings come loose as its pushed back in.
must have worked as the electrics passed with flying colours when I had my consumer unit replaced.
Posted : 26/03/2013 1:18 pm
or even less.
http://www.screwfix.com/p/ced-plug-in-socket-tester/76975
is it the same RCD every time ?
Posted : 26/03/2013 1:20 pm
jam bo - many thanks, off to screwfix later !
Trailrat - yes, upstairs sockets - loads of them to go round though !
Posted : 26/03/2013 1:26 pm
I've heard of this when the conductors at a socket (or a chocolate block joint buried in plaster) are in contact with a damp wall. During rain/winter/having a bath it can trip due to current leakage
Posted : 26/03/2013 1:36 pm
Had similar with the upstairs lighting circuit. Back box had cut the insulation during fitting it seems so as it moved a little with temp. it would trip. Visual inspection with the circuit dead might be useful.
Posted : 26/03/2013 1:40 pm
