Eaves filler foam
[Closed] Eaves filler foam
4 Users
My garage is drafty, it has concrete roof panels with a fairly common 5" corrugated profile. Unfortunately there don't seem to be any eaves filler foam strips for it, does anyone know of any that I've not found or will I end up having to mask off and use expandy foam?
Posted : 14/04/2011 1:00 pm
[url= http://www.comptonbuildings.co.uk/ ]Compton Garages[/url]
My parents have a garage from that lot and it comes with foam inserts for the gaps, if you contact your local supplier they may sell you some?
Posted : 14/04/2011 1:06 pm
Cheers, I'll poke a phone call at them and see what they have! I can find 3" and 1.5" fillers everywhere but 5 seems to be a bit unusual.
Posted : 14/04/2011 1:21 pm
Can't you just stuff it with bog standard loft insulation??
I've used M C S Roofing & Cladding before, they're based in Leek if thats any good
Posted : 14/04/2011 1:41 pm
Loft insulation would blow right out, it needs to be bonded in place. I'm hoping to reduce the damp problem the garage (and my bikes) suffer from lol. Leek is a bit of a way from me, I'll check out if they're online.
Posted : 14/04/2011 1:43 pm
Like this:
Posted : 14/04/2011 1:45 pm
Surely sealing up a pretty good method of air circulation is only going to increase the damp issue??
Posted : 14/04/2011 1:46 pm
That's the way the damp gets in, it's fairly well sealed elsewhere. Open to suggestions though.
Posted : 14/04/2011 1:59 pm
