E-Clip Experts
[Closed] E-Clip Experts
I' sure someone here is an expert on the above^^
I need to replace a really tiny E-Clip as seen on the picture below.
Do you reckon this ebay e-clip will fit ?
http://www.ebay.co.uk/itm/2-5MM-EXTERNAL-E-CLIPS-CLIP-CIRCLIP-DIN6799-pack-20-/270661240441?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DMRU-220%252BUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D21%26pmod%3D271109173014%26ps%3D54
Any thoughts.
[url= http://farm8.staticflickr.com/7375/9092887983_a2a09556b5_b.jp g" target="_blank">http://farm8.staticflickr.com/7375/9092887983_a2a09556b5_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/9092887983/ ]P1120388[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm3.staticflickr.com/2847/9092888247_dca3c65d8b_b.jp g" target="_blank">http://farm3.staticflickr.com/2847/9092888247_dca3c65d8b_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/9092888247/ ]P1120391[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 20/06/2013 6:28 pm
I don't think so.
I reckon that shaft has an OD of 2.4mm and the ID of the e-clip is 2.5mm.
Could be wrong.
Posted : 20/06/2013 6:41 pm
It'll be less than that; the section where the circlip sits is thinner than the OD you can see. I'm guessing it's about the same as the black tip, which looks to be ~1.6mm.
Posted : 20/06/2013 6:52 pm
From http://stores.ebay.co.uk/CLIPS-BITS?_trksid=p2047675.l2568 they do one:
10 x 1.5mm 2-2.5mm
That's the one you'd need, I reckon. If I were you though, I'd email them your picture and ask them the question.
Not cheap, are they?
Posted : 20/06/2013 6:55 pm
Sounds about right to me.
I Am Not A Circlip Expert.
Posted : 20/06/2013 7:04 pm
Also,
There's a DIN standard for circlips? Who knew.
I Am Not A Circlip Expert. "
As far as I'm concerned you are at the moment.
Thanks.
Posted : 20/06/2013 7:11 pm
I mean Expert ^^
Posted : 20/06/2013 7:27 pm
Is that £9.99 EACH?!!
Danny B
Posted : 20/06/2013 7:30 pm
pop it off (carefully) and measure the diameter.
Or better still the groove diameter with some calipers.
Something like the 1.5mm should fit though by the looks of it.
Posted : 20/06/2013 8:02 pm
