Drilling out screws
[Closed] Drilling out screws
HELP!!!
My oven element has gone kaput, but I can't get to it due to the screws being corroded and rounded.
My metal drill bits at low speed haven't done much, but I think they may be crap.
What are the best type of bits for this job??
Posted : 13/10/2016 8:44 pm
HSS or a cobalt one at a slow speed
Posted : 13/10/2016 8:46 pm
Ti coated metal drill bits, Dormer are good quality, keep their edge longer than the cheaper varieties and won't snap or break too easily.
Posted : 13/10/2016 8:48 pm
I found sometimes running a metal bit in reverse can bite enough to shock the thread free so you can get the screw out.
Posted : 13/10/2016 8:49 pm
Got a Dremel handy?
Cut a slot for a flat driver or cut off the screw head?
Posted : 13/10/2016 9:01 pm
Cheers! Bloody overpriced piece of shit er I mean Smeg!!!!
Left handed drill bits can be useful. I know it sounds like a joke, it's not! But screws are tricky to drill, unless you're happy to just take the head off, crosscutting the head often works better. Working on ovens is rubbish tbh
Posted : 13/10/2016 9:05 pm
EZ outs are the answer quite cheap as well.
Posted : 13/10/2016 9:18 pm
if anything of the screw is protruding grip it in the jaws of the drill driver
Posted : 13/10/2016 9:27 pm
Use a screw remover ? i.e. drill a pilot hole and then screw in a left threaded removal screw.
Posted : 13/10/2016 9:30 pm
Just reserved some EZ outs from screwfix ๐Ÿ™‚
Posted : 13/10/2016 9:40 pm
if the heads are on these are good
http://www.trend-uk.com/en/UK/productlist/2/78/grabit_screw_remover.html
cheap screw extractors usually cause more pain than gain.
Posted : 13/10/2016 10:24 pm
Just my 2p worth. I bought some bomber z1's with a snapped off brake boss in. Tried to use some cheap ez outs and they didn't help at all. Couldn't get them to bite.
Ended up using a cobalt bit to slowly drill the majority of the screw out. Then ran a tap through it to clear the remains of the screw out of the threads.
So far so good - the new brake boss screwed in fine and hasn't pulled out.
Posted : 14/10/2016 9:39 am
