Do some wireless ro...
[Closed] Do some wireless routers have better range than others?
4 Users
And if they do, can you recommend a nice, cheap, secure one that has a good range?
Posted : 31/03/2011 9:47 pm
if your router is capable, then a high gain aerial would be my first, inexpensive, port of call.
http://www.topsellings.com/en/high-gain-wireless-wifi-antenna-wlan-5dbi-rp-sma-rpsma-p96.html?language=en&currency=GBP
Posted : 31/03/2011 9:49 pm
How do you know if it's capable Stoner? Would something like this fire my signal out to the back garden then?
Posted : 31/03/2011 9:55 pm
another tack to take is a range extender.
Ive tried two, the first was shite, this has been pretty good:
http://www.amazon.co.uk/NETGEAR-WN2000RPT-Universal-Range-Extender/dp/B003JHQ3ZW
I live in an L-shaped barn with very thick walls and the router is located at one end of the "L".
dd - I doubt it*. All it does is improve the gain on your existing wifi output.
*but for a couple of quid there's no harm having a go
If your router has an external aerial that can be unscrewed then something like that hi-gain aerial can add some range.
to really get some penetration the repeater is a good idea (just needs power connection).
If you want to rig up an outside office, then you can try either:
cat 5 cabling
"homeplug" network system if within range
wifi external repeater that sends a focussed signal between two points.
Posted : 31/03/2011 9:58 pm
... or add an additional access point if you can get some Cat 5 into the area where you need access. You can pick up some models on Amazon for less than £20
This one has power over ethernet, which is quite handy:
http://www.amazon.co.uk/TP-Link-TL-WA701ND-150Mbps-Wireless-Access/dp/B002YETVVE/ref=cm_cr_pr_product_top
Posted : 31/03/2011 10:00 pm
Ha ha ha ha ha
I ****ing wish...
...More like "how to" vids from YooToob when bike fettling outside in the Summer 🙂
Posted : 31/03/2011 10:02 pm
bollox, you want to stream grot to your man-cave
Posted : 31/03/2011 10:05 pm
