DIY people - blind ...
[Closed] DIY people - blind fixings for use on wood?
Hi STW,
I need to hold a bracket to a sheet of 18mm ply, with a counter M4 bolt, and a nut on the rear. The bracket needs to sit flush with the ply.
Previously, I have used an M4 T-nut on the rear with success. However, this time I cannot access the rear of the board. I would rather not use a wood screw, so am trying to figure out the sturdiest/cheapest/easiest alternative.
Would these hollow wall anchors work?
https://www.screwfix.com/p/rawlplug-hollow-wall-anchors-m4-x-40mm-20-pack/54782
Or do they only work on set thickness plasterboard (for the shoulder to sit inside)? Also, I may need to countersink the plug into the ply a little so that the bracket can sit flush. Would also rather not have to buy the tool for it too.
Any better options?
Thanks,
Duane.
Posted : 17/10/2017 5:09 pm
Why the objection to wood screws?
You could use a spring toggle fixing, but then you'll need to drill a wider hole to get it through in the first place.
Insert nut? Again, big countersunk hole needed, don't know exactly how strong they are.
Posted : 17/10/2017 5:17 pm
The brackets/fixings may be under quite a bit of force (both tension and shear) - and not sure if wood screws will hold.
Posted : 17/10/2017 5:24 pm
You appear to have broken the screwfix site. However, decent woodscrews have a very good hold, just use more?!
Posted : 17/10/2017 5:31 pm
Ha yep, Screwfix appears to have keeled over!
Each bracket only takes 3 screws/bolts unfortunately.
Posted : 17/10/2017 5:48 pm
You might be surprised what a screw will take. Arguably it's got better purchase on the inner ply layers, rather than a nut on the outer ply. Arguably it's not.
How about a wide coach screw?
Posted : 17/10/2017 5:55 pm
You can get threaded inserts for wood, Type D, and can buy them from screwfix but I think the smallest size is M6, so you could open the holes on your brackets. They have a countersunk flange, and need a bit of clearance on the pilot hole depending on wood hardness.
Another possible option is to mount brackets on to a separate piece of ply and then screw this to the board that you can get access to the back of.
Posted : 17/10/2017 5:58 pm
Assuming that you have space behind, make keyhole-shaped holes; hole to match nut diameter, 4mm slot below. push the nut (on the bolt!) through and slide down. The shelf/brackets will hide the keyholes
Posted : 17/10/2017 6:53 pm
