DAC For TV to ampli...
[Closed] DAC For TV to amplifier
9 Users
I've got a cheap one at the moment £40 but it sounds muffled with little treble getting through. Must have RCA out and optical in. No more than £100.
Thanks
Posted : 13/04/2022 8:22 am
Cough👍
Posted : 13/04/2022 4:50 pm
Is there no straight TV to amp option? What connections have you got on each?
Posted : 13/04/2022 5:04 pm
No other audio out apart from optical otherwise I would have used it to the RCA on my nice old amplifier.
Posted : 13/04/2022 5:06 pm
That’s a shame. No real recommendations you might have to try the Amazon lottery - I suspect in the £50 to £100 range they are much of a muchness.
Posted : 13/04/2022 5:09 pm
What about your CD player? Or could you pick up an older marantz pm6006 which has optical in.
Posted : 13/04/2022 5:12 pm
You only have TOSlink out on the TV and only have RCA analogue inputs on the amp?
Posted : 13/04/2022 5:38 pm
Time for a new AVR and TV? Admittedly, a bit more than £40.
Posted : 13/04/2022 5:40 pm
Cougar
Yes
Posted : 13/04/2022 5:59 pm
Wow. Is it a CRT and a valve amp? 😁
That's kinda where I was leaning. A £100 DAC to replace a £40 DAC doesn't feel like the right solution here. Maybe the OP would be better served with a sound bar?
Posted : 13/04/2022 6:35 pm
Second hand Topping E30 or similar would be my pick at under £100 with optical.
Posted : 13/04/2022 6:36 pm
Had this when I got a new TV. Old one had RCA outputs and went into the Arcam amp fine. New one only has a toslink output. Amp is an old A85 so no digital input.
Got one of these back in 2019, seems fine to my ears.
https://www.amazon.co.uk/dp/B00KNNSKV0?ref=ppx_pop_mob_ap_share
Oh and
A £100 DAC to replace a £40 DAC doesn’t feel like the right solution here. Maybe the OP would be better served with a sound bar?
I much prefer the sound of may TV amp and speakers than I do various Sonos soundbars I've heard. Plus a cheap DAC is much cheaper 😀
Posted : 13/04/2022 7:09 pm
No headphone output?
My TV has optical out but until I got a new amp with built in DAC I used the headphone socket, I think it could be configured as line level fixed volume.
My previous TV I could never get the sound to sync properly using an external DAC.
Posted : 13/04/2022 7:50 pm
Cambridge Audio DacMagic 100 DAC - Black - Refurbished
Currently on eBay for £129 with 20% off
Posted : 13/04/2022 8:07 pm
Thanks everyone ☺️
Posted : 13/04/2022 8:38 pm
I'm in my caravan and whilst the JVC in the bedroom has all sorts of outputs, the LG in the lounge hasn't - only optical.
I want to use my JBL Xtreme 2 speaker as a mini soundbar - or even the caravans in-built speakers (via a the built in car stereo head unit) - they both have aux in and bluetooth
Swappining the TV's round isn't an option, due to the bracket mounting positions
I'm pretty sure I have one of these kicking about unused somewhere that I bought to try with my Sony WHX-M3 headphones, but felt the in-built Sony DAC did a better job
M-Dac
This can do aux out and BT, so theoretically should do a job.
Question is - will this sound ok for my intended use? Also, could I run the JBL and the caravan speakers simultaneously (might sound horrific)  from the one DAC?
Posted : 22/04/2022 9:04 pm
