DAB car radio cut o...
[Closed] DAB car radio cut outs
12 Users
There are a couple of areas near me where my car radio cuts out for 100m or near junc 10 M25 for about 300m. I just wondered if anyone knew what caused that to happen?
Posted : 01/08/2017 1:20 pm
S:N ratio.
get a bigger antenna.
Posted : 01/08/2017 1:22 pm
 StuF
My dab drops out a lot more if I've got my phone charging in the car
Posted : 01/08/2017 1:23 pm
Your car feels sorry for you.
It's having a minutes silence because you're near London.
It's probably pining for the fjords.
Posted : 01/08/2017 1:26 pm
DAB radio has more pronounced drop offs than normal radio. i have places where it goes dead in the same place every day. its just what they do.
Mine does it in a couple of places and being digital it has the signal or not so goes silent where an FM would have just had more interference.
Is it a proper in car DAB fitted by the manufacturer or a home fit jobbie? if the latter then consider a proper DAB aerial fitted to one of the rear windows.
Posted : 01/08/2017 1:27 pm
StuF - Member
So did mine, and then I changed the USB charger for a different (more expensive) type, bought it from Aldi. Now no problems.
Perhaps I should expand....its not a loss of signal due to geographical issues, I believe its interference causing me to lose the signal, as its doesn't matter what radio station I'm on. Its the same in the wife's car.
Posted : 01/08/2017 1:44 pm
In my car if it looses DAB signal it automatically switches to the FM version and then switches back to DAB when signal is back
Posted : 01/08/2017 1:47 pm
Fine if you're listening to Radio 1, not so much if you're listening to DAB-only stations.
(Why would you want it to switch back to DAB if it's available on FM anyway?)
Posted : 01/08/2017 1:51 pm
 StuF
@codybrennan
thanks - might have to steal the charger from the wife's car
Posted : 01/08/2017 1:54 pm
there will be some dead zones for DAB that you won't be able to do anything about. Compared to driving with FM they're few and far between in my experience. Where I don't get DAB there's no FM either (deep in the hills of Wales or Cubria. Banks of Scottish lochs. About a mile on the A303)
Posted : 01/08/2017 2:10 pm
DAB works by multiplexing different stations together into one combined digital signal - the receiver demodulates the whole lot and then picks out the data stream for whichever station you actually want to listen to. So it could be localised interference, but doesn't rule out just being a dead spot in the coverage.
Posted : 01/08/2017 3:16 pm
[i]near junc 10 M25 for about 300m.[/i]
That's about an hours 'driving' then 🙁
Posted : 01/08/2017 3:18 pm
