D5 volvo engine pro...
[Closed] D5 volvo engine problem.
Just taken my ma's v70 to fill her up. After 5/6 miles put my foot down and at. 4k the engine just cuts out. No power steering. Nothing. Seems fine upto 3k. Any more and it dies.
Thoughts?
Posted : 19/07/2014 8:31 am
Throttle position sensor?
Had a work car astra that did similar.
Posted : 19/07/2014 8:47 am
Do you get any engine warning lights come on when it cuts out? And does it come back again when the revs drop/you take your foot off?
Could be a blocked fuel filter maybe/dodgy fuel pump, or something more drastic ๐Ÿ˜‰
You definitely filled up with diesel and not petrol?
Posted : 19/07/2014 8:50 am
Diesel/Petrol? What year?
Going back a long time there was a throttle body issue that resulted in the car going into limp home mode but this sounds different.
Posted : 19/07/2014 8:53 am
Sounds like fuel filter clogged up. Change it, don't use cheap ones buy OEM, and see how it goes then.
Posted : 19/07/2014 9:31 am
Link to a forum that has been great with any issues I had with my petrol V70.
For your D5 both the v70 and diesel engine subforums have heaps of info and helpful Volvo users.
http://www.volvoforums.org.uk/forumdisplay.php?f=113
good luck.
Posted : 19/07/2014 9:35 am
I had similar with my mum's D5 last year - it was the fuel filter.
Posted : 19/07/2014 10:08 am
Had a couple of these with split intercoolers.
Posted : 19/07/2014 10:20 am
Diesel, 52/3..iirc. no warning lights, apart from it tells you parking light bulb out. despite it not being.
Its due a service, so fuel filter check, if not split intercooler.. yay.
It didnt go into limp mode, engine just died. Need to get a reader on it I guess.
I cant do it as on way to whistler so ill pass the info on. Cheers.
Posted : 19/07/2014 11:21 am
Code reader will not show a fuel filter problem.
Posted : 19/07/2014 11:24 am
