Crib Goch. How hard...
[Closed] Crib Goch. How hard is it?
On a fine still summer's day it's fine. Completely different when it's wet and blowing a hoolie.
When we lived in Llanrug (between Llanberis and Caernarfon) I used to take our black lab round the Snowdon Horseshoe with no problem - then again he had four paw drive!
Posted : 28/08/2020 10:13 pm
And having looked at the photos that’s confirmed it, absolutely no way, José! 🤢
Could be worse...
https://www.flickr.com/gp/matt_outandabout/2M5m6c
Posted : 28/08/2020 10:24 pm
 Spin
Could be worse…
https://www.flickr.com/gp/matt_outandabout/2M5m6c/blockquote >
The Aonach Eagach is another one that gets a bit more sketchy in the wet. First time I did the Glen Coe Skyline I got through the exposed scrambly bits before the rain hit and everyone behind me took about twice as long!
Posted : 28/08/2020 10:33 pm
Honestly thought this thread was going to be about a hipster re-imaginating of the game of cribbage.
Posted : 28/08/2020 10:36 pm
@Spin - only done the Aonach Eagach once and that was in winter, either 1985 or 1986. We had a Brocken Spectre for almost the entire length of the ridge, quite magical.
Posted : 28/08/2020 11:10 pm
 Spin
Never done it in proper winter nick but sure I will at some point!
Posted : 28/08/2020 11:21 pm
Nothing to add on the original question but learning about 'Brocken Spectre' and 'verglassed' was worth reading it on its own.
Posted : 28/08/2020 11:43 pm
Absolutely do not do the Clogwyn-y-person arete, it’s a grade3 scramble
Just so it's clear, I wasn't suggesting that the OP even think about that, it was more for the benefit of anyone who climbs and fancies a more interesting start to the day.
Posted : 29/08/2020 8:50 am
I wouldn't even give a grade 3 scramble a second look.......grade 1 is my absolute limit....sometimes more than my limit!
Posted : 29/08/2020 2:54 pm
I've only ever done it in winter, it's fairly straightforward, only technical bit IIRC is the descent from the far end, or if you do it from the Glen Coe end it's an easy ascent even covered in snow.
Certainly not in the same league as the harder ridges eg Tower Ridge, although when we did that it was the reputation of the route rather than the actual route that we feared more.
Posted : 29/08/2020 4:32 pm
CG is walking on a knife edge with no banister, so different.
Not really. If you're not confident enough to stroll along the top with your hands in your pockets then (assuming you are on the way up to Snowdon) just drop down a couple of feet to your left and use the top of the ridge as a handrail.
About half way across you will see a narrow flat slab. This is where it is customary to do a head stand if you are confident/stupid enough.
Posted : 29/08/2020 5:54 pm
 Spin
There's about 50m in the middle of TR that I haven't done in winter. I've gone down it from the top of Italian RH and up it from the top of Stringfellow. 🙂 No doubt I'll fill that gap at some point!
Posted : 29/08/2020 6:25 pm
Page 2 / 2
