Covering artex/wood...
[Closed] Covering artex/woodchip
13 Users
A few ceiling at Chateau Al have woodchip on them, stuck straight onto plasterboard - so if you try to strip it you end up taking off half the paper on the 'board, making a right mess.
How viable would it be to use the artex covering stuff? Is it much different to plaster?
Posted : 08/10/2011 9:22 am
just get a plasterer in.
better job, not that expensive.
Posted : 08/10/2011 9:24 am
Usual solution is to fix new plasterboard on top then skim coat
Posted : 08/10/2011 9:25 am
You tried a steamer and patience already? We had a builder who stuck a new layer of plasterboard on top of artex. He was working in the room anyway, so the cost was part of a big bill.
Posted : 08/10/2011 9:53 am
Don't have it skimmed as later it will separate. Either plaster boarded or removed.
Posted : 08/10/2011 10:03 am
Skim over it with carbon fibre
Posted : 08/10/2011 10:31 am
to:
Is wot I'd do anyway. A bit expensive but worth it for a nice finish IMHO.
Posted : 08/10/2011 10:32 am
you can skim over artex, but make sure the artex is sound and not hollow/bubbling away
Posted : 08/10/2011 10:36 am
Our bathroom ceiling was artexed.
We just screwed a big piece of plasterboard up over it and skimmed round the edges. Took about half an hour.
Well I say 'we', I got some bloke to do it.
Posted : 08/10/2011 10:37 am
The ceiling in our lounge is an inch lower than the ceiling in our kitchen. I suspect someone fixed plasterboard and then artexed over it! Going to be interesting when we knock the wall down between the two 🙂
Posted : 08/10/2011 10:49 am
We had those awful polystyrene tiles in our bedroom (old victorian house with high ceilings). Rather than pull them down, I put up a stud framework using 4X2. Plaster Board then skim.
It's now the flattest surface in the house, with the added bonus of having an insulated void.
Posted : 08/10/2011 11:50 am
Set fire to your room it's the only way.....
Posted : 08/10/2011 12:30 pm
If only I had no coving...
Posted : 08/10/2011 12:37 pm
i had a fully woodchipped spare room which i ummed and arred with, in the end i stripped the woodchip then skimmed with that polycell smoothover. The result is quite impressive and I have since used it again. I figuerd it was 30 quid and a bit of graft, if it didnt work out i was gonna get a plasterer in. oint buy the b and q smoothover though, it is rubbish and very hard to get a good finish ime. The polycell is very easy to use
getting the woodchip off was a pain but seemed to work best if you took the outer layer off dry then soak the backing and peel off. Steamer didnt realy help and wrecked the plasterboard
Posted : 08/10/2011 1:49 pm
