Copying DVD W10
[Closed] Copying DVD W10
6 Users
How do I simply copy a the contents of s DVD in W 10. Haven't done such a thing for years but I am darn sure it was easy. Everything on the web looks complicated and no two web searches are the same. Why can't I just right click and then click copy and send it to a pc folder and then later send to it to a DVD?
Posted : 21/01/2016 7:55 am
Film dvd or data?
Posted : 21/01/2016 9:25 am
Not done that in W10, but I'd probably install ImgBurn which is what I use for things like that on W7 - just remember to untick the boxes for the optional crapware when you install it.
Posted : 21/01/2016 9:32 am
Convertx to dvd still works fine in win 10.. If you're converting some other video format to dvd and burning to physical dvd disk.
Posted : 21/01/2016 9:54 am
ImgBurn will copy and burn a DVD if you just want a straight copy.
Note it won't deal with copy protection if it's a commercial copy protected DVD (noting copying even your own legally purchased DVD in the UK is illegal. There are various tools that deal with the copy protection but I guess shouldn't be mentioned here).
If it's purely data, you can just open the DVD in Explorer and copy the files to a folder, then use something like ImgBurn to burn them back, or I believe Win10 still has support for copying files onto a blank DVD.
Posted : 21/01/2016 12:10 pm
Thanks. Now in English please 😯
Posted : 21/01/2016 4:54 pm
Its a copy of a copy of a copy of some video
Posted : 21/01/2016 4:55 pm
Not commercial and not copy protected then? Install ImgBurn and select copy on the main menu. Though I presume W10 has built in support which would probably work just as well. Especially if it's just a file on the DVD, which you should be able to drag and drop using file exploder.
Posted : 21/01/2016 4:57 pm
Is it a DVD that you stick in your DVD player and watch on the telly, or a DVD-ROM that stores files from a PC?
Posted : 21/01/2016 4:58 pm
