Converting PDF'...
[Closed] Converting PDF's
Is it possible to convert a PDF document into a text editable document ?
Cheers.
Posted : 12/11/2009 2:09 pm
As far as I know the only way is buying adobe acrobat.
Posted : 12/11/2009 2:10 pm
google it. there are loads of options.
unless the creator of the pdf has restricted it so you cant.
Posted : 12/11/2009 2:12 pm
as long as there are no pics in and you don't mind re-formatting it all you could try to copy and paste into word etc
Otherwise try CUTE PDF ( it's free ) and I think you can edit PDFs in that
Then again I could be totally , horribly wrong ๐Ÿ˜‰
Posted : 12/11/2009 2:13 pm
If it's just text - copy & paste it into Word
I have googled it and tried a few different ones, but they only convert into a word document and not text editable.
Time is short and I hope that someone in the STW massive would be able to give a direct response or answer ๐Ÿ™‚
I normally use [url= http://www.pdfonline.com/pdf2word/index.asp ]PDF Online[/url] to convert documents from PDF to Word
Posted : 12/11/2009 2:20 pm
I wasted loads of time on this...
Think this is what I ended up using...
[url= http://freeware-pdf-unlocker.en.softonic.com/ ]unlocker[/url]
The fee version of [url= http://www.docu-track.com/home/prod_user/PDF-XChange_Tools/pdfx_viewer ]THIS[/url] lets you add notes / comments once the doc is unlocked...don't think it lets you full edit functions though.
Posted : 12/11/2009 8:52 pm
You can import them into Illustrator and you can modify the text
Posted : 13/11/2009 12:24 pm
Easier option:
I use Foxit free PDF reader, not Adobe.
In the File -"save as" there is an option to save the doc as text.
Job done
Posted : 13/11/2009 12:47 pm
