compressing pdf fil...
[Closed] compressing pdf files
9 Users
[dull&possiblynumpty]have scanned a shed load of docs that i need to email have converted to PDF's using the software that come bundled with Epson scanner - doesn't seem to have any options
- some 2 page docs are 4-5MB and won't email sit in outbox labelled "huge"
tried zip central and then winrar and even using best compress only compress a few %
any ideas - only soln i can see so far is buying acrobat which allows you to open and resave a lower resolution version
thanks [/dull dull dull]
Posted : 03/05/2012 10:04 am
If sending is the only problem, try sending it using this site
https://www.wetransfer.com/
Posted : 03/05/2012 10:09 am
Quick google found this? Might be dodgy as though! 🙂
http://docupub.com/pdfcompress/
Posted : 03/05/2012 10:15 am
Different method to achieve what you want.
Download CutePDF - it creates a dummy printer to which you can print your files. It'll then create a PDF of the print. This should compress the file size by making it appropriate to the size you're printing.
Posted : 03/05/2012 10:20 am
 xcgb
Is there a mac equivalent of cute?, I could use that!
Posted : 03/05/2012 10:34 am
 MSP
You probably just need to lower the resolution your scanning the documents in at.
Posted : 03/05/2012 10:38 am
XCGB - macs have a whole load of pdf options built in to the operating system, you can do quite a bit without needing any apps.
surely even if you are not connected to a printer you can still print to pdf as you're not actually printing anything physically?
Posted : 03/05/2012 11:18 am
 xcgb
Anus (i feel quite dirty typing that) I know, but i receive very large PDFs (500mb +) that I have to send of as proofs and it can be a pain getting them small enough especially when the images already have compression on
I work in the grand format printing trade (we wrap buildings and such)
Posted : 03/05/2012 11:34 am
thanks got it - Clubber set me thinking i have cutepdf but stopped using it when installed office 2007 as you can save pdf's in this directly
cutepdf halved the file sizes which for mulipages was still a prob
anyway scanned as .jpg's before converting so i had saved those and i guess could reduce resolution (f'ing epson software doesn't let you do this when you are scanning)
anyway copy and paste the jpg to word - save as : pdf for web publishing and job done about 10% ofsize resolution is crap but surprising ok for the end user
Posted : 03/05/2012 12:57 pm
Right click on file or folder -> Send To -> Compressed Folder.
Posted : 03/05/2012 1:21 pm
If you've got something like Photoshop you could Open the PDF file, then adjust the image resolution before saving it.
Posted : 03/05/2012 1:23 pm
