Cold radiator?
[Closed] Cold radiator?
Seems to have stopped working since yesterday
Entire radiator is cold, and the two pipes supplying it
All other rads are hot
TRV failed?
Posted : 01/11/2016 11:15 pm
Sticky TRV? I had to free up two this weekend.
Posted : 01/11/2016 11:19 pm
Sticky as in won't turn? Seems to turn fine
Posted : 01/11/2016 11:20 pm
No, unscrew it and make sure the valve thing sticking out moves.
Posted : 01/11/2016 11:25 pm
Yup, take the TRV off and try pushing and pulling the pin on the valve with a pair of pliers - apply a wee drop of oil if it's sticky.
Posted : 01/11/2016 11:32 pm
A per Al's advice above, there should be a small poppet type valve below the TRV plastic top section, unscrew the body of the TRV then using a pair of needle nose pliers carefully try and move the little rod in the center of the valve up and down to free it off.
Also would be worth checking that rad is not full of air. If the heating has not been on and there is a slow leak somewhere it may be that since water has been pumped round the system again all the air has migrated to the 1 radiator.
Posted : 01/11/2016 11:36 pm
On a similar topic, how much bleeding should a system need? Ours generally has an empty rad (the only one on the highest floor) at the onset of winter, I usually bleed it a bit during the winter too. Sign of a problem or nothing to worry about?
Posted : 01/11/2016 11:58 pm
It's certainly not right, but how much of a problem? It depends on the gas that you're bleeding:
Hydrogen sulphide (rotten egg smell) is unusual (and toxic) and is indicative of a bacterial problem
Hydrogen is caused by corrosion in the system and can be associated with a new system or components, e.g. a rad (it can also be long-standing)
Air is often either a leak or a pump problem
If it's not air then draining and using a cleaner/inhibitor in the refill will probably help (e.g. Fernox, etc)
Posted : 02/11/2016 7:26 am
