I've got loads of loose change - heard that at supermarkets you have machines where you chuck it in and get it out as something easier to spend but have to pay a fee.
Anyone used them - are there better ones out there I should keep any eye out for?
(Sorry wrong forum)
A bank will change, errrr change for you free. (you may have to bag it up though)
A bank will probably have a max value. The machines charge something like 5p in the pound - worth it not to have to count it yourself.
let a charity count it for you? 😉
The machines do take a percentage, but banks and building societies make it difficult by only allowing you take in a few pounds worth of change each day, Normally around £5 maximum.
Take it to a Bank and take a small child with you and tell the bank its from the small childs piggy bank, no charge. 😉
7p in every £1 hardly a major drama..
And a lot less hassle than bagging it all up IMHO.
No problem at some banks if you have an account & no limit - you do need to bag it up though
Coop is OK
Nat West is OK
not tried any others but I recently took £2k of change into the Coop [I have a smile account] & they were fine
I would however avoid busy times
uplink, your sofa must be an amazing place...£2k of change, yikes!!
I have a 6 litre beer keg [empty of course] with a slot cut into it that I empty my pockets into every day - so there's usually at least £3 often up to 10 going in most days
When I fancy something new - I cut it open
Supermarket machines usualy charge 10 percent (robbin bastids), I recently changed 850 quid in loose change at barclays for free. I do not have an account with them, I had it all bagged up ready and just took 250 quid a day in they changed it no problem.
I use those machines too, don't mind sacrificing 7p/£ to avoid having to bag it all up myself. Empty in tub of change, collect receipt and all the various foreign currencies and car park tokens from the reject tray. Besides, I like the clattery noise it makes.
Jesus!!! I've only got about £5 but need a brake outer for my daughters bike so am going to use one of those machines this time - once I've saved up more I might try the bank route.
If it's only a fiver just pay for the outer with it
I just feed them into those self service tills in ASDA, then pay what ever is left with card
Why don't you use your loose change for something more unconventional - like spending it in shops to buy things with? If you do that regularly enough you never build up vast quantities of the stuff.
Some banks now have loose change machines. The HSBC in Northallerton being the one I used - same as supermarket machines but no charge
If I break a note, I never put 1, 2, 5, or 10p coins back in my pockets when I'm next going out. I may not manage to spend them, and they just weigh my trousers down. I now have a heap of change, so I think I'll try the machine in Sainsbury's. 7p/£ sounds like a good rate of loss compared to the other arcade machines 😛
