Firstly it would be best to avoid placing any blame on what has occurred. lets just say we don't know how or why it happened and we will all move on to find the best strategy moving forward.
There is a reasonable about of chain marks on the house carpet. It seems to want to stay there and not be removed. it is in a location that nobody else has noticed (yet) but soon will be
What cleaning products and techniques would you recommend I try before there is a suspicious fire in the room that we don't know how that would have started either?
lets just say we don’t know how or why it happened and we will all move on to find the best strategy moving forward.
The first step to resolution is clearly to identify a scapegoat for you...the unknown offender.
It probably depends on the chain oil as to what might shift it. If it's Putoline you're probably stuffed. 😉
I assume you've progressed from
Bio degreaser through IPA to White Spirit already?
Have you tried a concentrated solution of lemon washing up liquid and a sponge/scourer or nail/old tooth brush? I'm pretty sure it was this combo that saved a charge on returning my old company car many moons ago.
I think step one is make sure you have written a will.
WD40 - disolves oil. Really.
Failing WD40, Screw fix no-nonsense degreaser.
Forget WD40
Isopropanol is the answer
We had a rental house a few years ago and I'd setup my turbo trainer in the converted loft which had a pink carpet!
Had to clean the place properly when we moved out and of course the pink carpet had oil marks on it.
Sprayed them with IPA, left for a few minutes then blotted with a cloth and removed every single oil mark
How many pages before killer is, well, killed?
Maybe Killer'sKiller will join the forum???
@killer we have a no blame culture but it's all your fault.
Degreaser, washing up liquid, scissors for a tiny carpet trim.
Got a rug you can cover it with? Or move the furniture about?
Baby oil has worked for me in the past.
Killer... a man not long for this world.
Name absolutely and definitely checks out for his Mrs though. Particularly after the chain oil marks now have wd40, lard, margarine and petrol stains added to them. 😁
Thoughts and prayers.
(Now expecting a post from a new member tomorrow called Mrs Killer about how to remove "claret stains" from carpet, curtains and the boot of a car.)
After doing your best with brake cleaner or IPA, a careful 'shave' of the carpet surface with a razor will remove just the very top surface and any residual marks. For extra sneakiness you can shave a bit of carpet fluff from a clean bit and glue it to the stained bit to camouflage it. This is a risky strategy as it is unlikely to survive first contact with the vacuum cleaner. However, if you are elsewhere when this happens, you have plausible deniability. A gambit that may work is 'that mark wasn't there when I left this morning, have you trodden something in whilst hoovering? Good luck!
Yeah, I can imagine but what about cleaning the OP's carpet?
You're all looking at this the wrong way. The answer is to ADD to the stains.
As you're a helpful chap, why don't you do some painting and decorating of said room. Then "accidentally" knock the tin of paint over.
Then claim on the home insurance for a new carpet.
Yeah, I can imagine but what about cleaning the OP’s carpet?
Many years ago someone in my house managed to get chain oil on a brand new cream carpet.
A user here who was a carpet fitter (I think it was the sadly missed Trout) suggested WD40. He also suggested you also give the door hinges a spray so that you can tell anyone else in the house that the reason it smells of WD40 is that you were fixing a squeaky door.
I can confirm it worked a treat on both accounts.
In a former life me, Mrs bloke and the little blokelets used to live in army married quarters. When vacating your quarter there was an inspection called a 'march out' by the 'estate warden' - usually an officious jobsworth wearing white gloves whose mission was was to discover and bill you for as much damage as possible. As a result, there were all sorts of dodges and folklore shared around to cover up marks and damage. The carpet shaving ruse is one I've used to good effect.
It backfires though when you 'march in' to a new place only to discover over the first few weeks, the bodges the previous occupant used to evade a damages bill. In my case this included boot polish to cover marks in the oven and holes in the wall filled with toothpaste. The best was when we first used a living room light and it started 'snowing' soon afterwards. Some enterprising wag had cracked a glass ceiling lamp shade and filled the cracks and a small hole with an icing sugar paste which melted when the bulb got hot! I was both annoyed and full of admiration!
Got a dog? Blame it.
Cover whole carpet in chain oil, so it doesn't stand out. 😉
Part and parcel of being a bike building cyclist I reckon. Goes with the territory.
I was trying to remove the oil seal out an old pair of bomber forks. Long screwdriver, knee behind the fork/screwdriver to brace it and the seal suddenly pops out, flies across the room and hits the cream coloured curtains,leaving a nice round oil stain thats been there ever since.
Is it a light colour carpet? if it's just one little spot, and you have some off cuts of the same carpet... a last resort could be to surgically cut out a square with a sturdy craft knife or similar where the spot is, and insert a plug cut from the spare bit, with a bit of glue on the underside.
Ruffle it up a bit once dry, and trim the pile down with some nail scissors if it stands out too much, so it blends in with the rest of the carpet.
But when you say
It's not sounding very promising for that kind of botch...
Probably time to start planning
A) pricing up new carpets
B) exit strategy
That's devious, I love it. 😁
Not really... don't work on dirty/greasy parts inside the house unless it's in a utility room/kitchen.
These are principles which every man of every faith can embrace.
These are not polite suggestions. These are codes of behavior, and those of you that ignore them will pay the dearest cost.
There are varying degrees of evil. We urge you lesser forms of filth not to push the bounds and cross over into true corruption.
I’d definitely go with the WD40/isopropanol/liquid soap, or even just IPA/soap, which has worked on greasy marks on tee shirts before now, and then a proper clean with the next batch of washing. Not that the carpet would go in the washing machine, of course… 😁
Before rendering the carpet squeak proof with WD40 I’d try baby wipes. Whatever the smeg they put in them will happily remove motorcycle chain oil from all sorts of places.
How did you discover what it was? "Oh, that's weird... I wonder what it tastes like?"
Dude, what the hell are you doing with your baby?
This is the correct answer and the solution to any stain related issues.
Firstly it would be best to avoid placing any blame on what has occurred. lets just say we don’t know how or why it happened and we will all move on to find the best strategy moving forward.
You are Matt Hancocks script writer and I claim my five pounds!
Elbow Grease got chain oil marks off my car seats.
Will he be discovered strangled with a bike chain lying in a pool of baby oil and WD-40?
Thanks,I was struggling on the intro to my first novel. 😆
The correct answer is moths.
Open the microwave door in a darkened kitchen to entice them in. Hack the stain out and the evidence for the defence m'lud is already remanded in custody.
Be ready with a Darwinian theory for the evolution of moths that eat polypropylene. Simples
WD40 can stain (very) light carpets.
But what sort of lunatic has carpets that light coloured! (My step mum, that's who.)
Brake cleaner is the stain remover of choice in my place, roof liners, carpets, clothes, i even used it to de-creosote the arm of a jumper that got covered. (The washing machine *might* have managed, but i didn't want a creosotey jumper in there!)
Kitchen towel or a clean rag can be pressed into service to blot/wipe up the worst of it once the brake cleaner is working it's magic.
The real question is if this is a double negative post and @Killer is actually the [s]victims[/s] forum members other half....
That's a slippery slope into some double entendres and gags we just don't need around here.
Suggest a European look and remove carpet and tile?
much easier to clean
1. Get a glass and a sharp knife, e.g. Stanley knife.
2. Move a piece of furniture to expose fresh carpet.
3. Place rim of glass on fresh carpet and cut out a circle.
4. Do the same over the oil mark.
5. Swap the circles and move the furniture back
6. Have a nice glass of red wine to celebrate.
Place rim of
glassbin lid on fresh carpet and cut out a circle.
FIFY
I’ve done that too, cream carpet… rug doctor got it out, liquid biological washing detergent 😊
good luck!
Fairy liquid massaged into the offending area and then put in the washing machine works well for removing oil / chain gunk from clothes. So just do the same with the carpet?
None of the above, biological washing powder mixed into a slurry and spread over the affected area, leave it for a couple of days, it will set but can be easily cleaned up with water.
Also works on oil stained driveways.
Bioremediation matters
So you're saying you were...pwned by Bombers?
I was about to recommend laundry liquid. You have to be careful with powder as the destainer might bleach the carpet where applied.
Really anything with a bit of alkalinity in it, e.g kitchen degreaser, will saponify the oil and get it out of the carpet.
Just be careful if using any solvents as these may affect the backing of the carpet
Prevention is always better than cure.
Either tile the floor, or get a Gates belt drive bike 👍
I think we have to come to terms with the fact that the op will never get to read this.
He shall be remembered and we can only but hope bikerists everywhere learn from this sobering lesson. 🫡
Happy trails friend, happy trails.
I'm guessing on the ladies forum there is a new member asking for advice on how to invest some inheritance she's soon to come into? Unfortunately we will never know.
Outside. Definitely outside.
Why is everyone assuming @Killer is male?
GT85 far better than WD40 and smells nice too
Dont rub it in though, spray it on and then absorbent kitchen crime etc dabbed on top, if your rub you just push it deeper in to the carpet
I’m aware that you can remove candle wax from carpets by placing a tea towel on the wax and then carefully go over it with a clothes iron on a low heat.
Maybe try the towel and clothes iron once you’ve got the worst of the oil out?
A hair dryer might work too. Kind of heat and capillary action…
Or, with a spare piece of carpet, add the oil, then drizzle some candle wax onto it and see if any of the above techniques work.
I note the OP posted on the Shane McGowan thread yesterday, sometime after this thread started. Maybe worries of their demise are premature?
Maybe he/she is not in A&E having a can of chain lube surgically removed? Or drowned in a bath full of fairy liquid and baby oil?
OP if you can read this, but are zip tied to the garage workbench, we are here for you. If you are being prevented from replying on this thread, try to send a sign of life on another thread. Can anyone think of a code they can use?
Thanks for all the tips everyone.
I am still alive, but working secretively in the shadows. waiting till the rest of the house is out then fetching out the cleaning supplies. we're making good progress on the offending marks, but still not out of the woods yet.
I've yet to resort to baby oil though. Might keep some on the bed-side table just in case though. That won't arouse suspicions right?
I’ve yet to resort to baby oil though. Might keep some on the bed-side table just in case though. That won’t arouse suspicions right?
Are we saying that baby oil is the matrimonial version of 'Look, an Otter!'?
Eucalyptus oil.
Put it on a cloth and dab the stain.
Advice given to me by bloke who installed carpet and it works like magic.
I'm thinking that even if the stain is gone, the combined aroma of GT-85, WD-40, eucalyptus oil, IPA, baby oil and brake cleaner might arouse suspicions? That or the house will be flattened when the OPs OH lights a candle to get rid of the pong and ignites the cocktail of volatile organic compounds.
Nearly spat my tea out at that. Thanks... 🙂
This was the solution to OPs problem all along. Set OH up to destroy the house, shrug shoulders, "What stain darling?"
What bike(s) are we going to be getting from Mrs Killer for the cheap cost that he told her they were?
There will be others along very soon to state that the bikes are not worth anything, certianly not worth the potential blood stain on the carpet and associated cleaning fees
Gordon's OP is alive!
When I first got a Turbo Trainer I set it up in the spare room.
Popped the bike on, did a 30 minute session. Got off to see a nice streak of oil on the pale coloured carpet. Never even thought about oil being thrown from my freshly oiled chain! 🙂
The stain never did come out!
