Any plumbers about? I have a cellar converted into a kitchen (it was converted when I moved in). There is a pump to get rid of the water from the sink and the washing machine. It has started making a very brief pump noise every 60 seconds or so - with no water running through. It was even doing it after I had been out at work all day and therefore 8 hours + without a tap running. Can I do anything to fix it myself? Is it totally broken or fixable?
Thanks
it could be an air lock dude just crack it open a bit with a screwdriver from the font and let air out try that fisrt if its three speed make sure its on three ?
/sucks teeth
Sounds like your giffer valve is screwed mate. It's probably taken the worm drive with it too. It'll cost 800 quid to fix. I can come round in three weeks to sort it or if you pay an extra grand I'll get on it tomorrow...or the day after. It's doing more damage the longer you leave it mind.
mmmmmmmmmmmmmmm call a local plumber dude
there only 400 new.. a fool could fit one, which is why many pumbers do/
I had a similar problem with mine. Took it apart, which is dead easy, and found that the pressure switch was knackered. IIRC I found a local distrubutor for the pump who supplied a replacement switch for about £10
Its stopped - by the time I got back from work tonight!!! All good, it must have just been having a moment. Thanks for all your help everyone.
