Car tyres Bargainta...
[Closed] Car tyres Bargaintastic advice ( not cheap cruddy tyres)
2 Users
I have been using Prestivo tyres on the front of my Picasso for 20k miles on a 185/65/15 and alas mrs SD hit a pot hole and blew the tyre out. I checked the warrentee and found this below
Prestivo Accidental Damage Guarantee.
This tyre is guaranteed against accidental damage - that means if you damage it and we cant fix it we will give you a discount on your replacement tyre of up to 100%.
The discount is based on the unused portion of the tread, so if the tyre is unworn you get 100% discount, 50% worn, 50% discount. 90% worn 10% discount. Simple!
Prestivo is made by a leading manufacturer and combines great handling especially in the wet, with class beating durability....Check Size Availability
Tread Remaining Discount
8mm............100% allowance
6mm-8mm....75% allowance
4mm-6mm....50% allowance
2mm-4mm....25% allowance
below 2mm....nil allowance
Returned to the tyre dealer, [b]no quibble replacement tyre £15 [/b]
These tyres ar £56 each which is £35 less than equivelant mitcheline's (which at 20k are knackered) and should be good for 40k+ and I have never had any grip issues with them so perhaps [b]Cheap tyres can be good[/b]
Posted : 15/01/2011 4:44 pm
hope this helps folk
Posted : 18/01/2011 6:53 pm
yep. got a screw in the side of one of mine a couple of month old and got a new one for about £15
Posted : 18/01/2011 6:55 pm
