calling any sonos e...
[Closed] calling any sonos experts please?
im still trying to stream the same music to two rooms as easily/cheaply as possible-without having my laptop turned on.
i already have an NAS
i already have two home cinema systems with a spare digital toslink connector in each
i have an ipod touch to control it all
but what sonos bits do i need and does anyone have any for sale,thanks lesreynolds1967@gmail.com thanks
Posted : 14/08/2012 8:02 pm
We have a "connect amp" and two "play.3" amps which is enough for music throughout a two bedroom terrace. All our music is on a hard drive which took a long time but is worth it for ease.I was very sceptical about this system, but it has totally changed the way I listen to music at home. If you have a smart phone, you use that as a controller so you don't have to buy a separate one.
Posted : 14/08/2012 9:55 pm
If you just want to use the sonos gear to play music with your existing home cinema systems you will just need a sonos connect (possibly one for each home cinema system, sorry I didn't quite understand if you meant you had already connected the two home cinema systems together..).
Basically a sonos connect has (among other outputs) a digital output which you can connect to your home cinema system.
Had ours (sonos connect + 2x sonos play 3s) for almost a year now and think its a great set up.
Posted : 14/08/2012 10:11 pm
