Building Warrant - ...
[Closed] Building Warrant - DIY
13 Users
I've heard the paperwork for a BW is straightforward, and am planning an ensuite, requiring a macerator and soil going into a rain water drain (NOT a soak away).
Any hints...tips...online resources?
Posted : 24/12/2011 5:04 pm
Thought sewage wasn't supposed to go to surface water/rain water drains
Posted : 24/12/2011 5:17 pm
sewage goes in sewage pipes surely
Posted : 24/12/2011 5:19 pm
So does rainwater if the property is connected to the main sewer.
And there's no a soak away of course.
Posted : 24/12/2011 5:24 pm
We've done that bit before....builder has told me it WILL BE legitimate...
..any knowledge re. Building Warrants thanksyouplease?
Posted : 24/12/2011 6:12 pm
Whats a building warrant?
Posted : 24/12/2011 6:19 pm
I have no idea either......is it the warranty you get on new builds ?
Posted : 24/12/2011 6:24 pm
I have no idea either......is it the warranty you get on new builds [b]in Scotland[/b]?
[img] http://www.smileys4me.com/getsmiley.php?show=2141 [/img]
Posted : 24/12/2011 6:26 pm
Yeehaa. (smells a cowboy)
Building control is what you're probably after. Speak to your BCO (building control officer) at the council.
Posted : 24/12/2011 6:31 pm
Maybe it's a typo and he meant he's building a warren ?
....fully plumbed in with an en-suite for a very happy bunny.
Uh...yeah...they are called building warrants up here in Scotchland, you need one for most alterations (I've had 2 done for me before).
I am disappoint in your lacks of knowledges, but thanks and happy birthday regardless 😀
Posted : 24/12/2011 7:00 pm
The the concil dept. You need proper drawings, I will be very suprise if you get permission to put sewage int eh rainwter
Posted : 24/12/2011 7:18 pm
Technical handbooks here - http://www.scotland.gov.uk/Topics/Built-Environment/Building/Building-standards/publications/pubtech
As you need more detailed drawings than for a planning application, I'd be persuaded to get a professional to do them.
I'm sure TJ can recommend an architect 😉
Edit: Seriously, try and find either an out of work architect or architectural technician to do them for you
Edit 2: Speak to the building control officer about the mascerator before you go too far down that route.
Posted : 24/12/2011 7:35 pm
Geoffj speaks sense.......
...... Apart from the TJ bit.
Posted : 24/12/2011 7:42 pm
Cheers...and TJ we've done that already!
Happy XMas 😀
I'd add I'm not working just now so can "devote" a fair bit of time to it.
Posted : 24/12/2011 8:07 pm
Yep connect to a soil stack....
Posted : 24/12/2011 10:11 pm
Do you really need a BW for that? Also talking to the coooooncil... I would make an enquiry without giving too much of your address away.
Also if you need an architect and or structural engineer I can recommend someone in Edinburgh...
HTH
Posted : 24/12/2011 11:14 pm
Yep def needed - if I were to sell the house any potential buyer would check with the council and it would show up.
Ta re contacts tho, will bear in mind.
Posted : 25/12/2011 6:42 am
For such a small job it should be a breeze to get through Building Control. I done quite a few homers for family over the years, drop me a mail if you need a hand.
Posted : 25/12/2011 2:22 pm
Thanks, that was I was hoping!
Posted : 26/12/2011 10:27 am
