why would my car be...
[Closed] why would my car be buring a lot of oil ?
20 Users
ive an old petrol fiesta and its using about a litre every 250 miles any reasons for this ? ta
Posted : 24/02/2009 8:12 pm
The rings are stuffed. Time for a rebore & new piston & rings. & bearings too.
Posted : 24/02/2009 8:23 pm
time for new car lol its only a cheapy to get me thru til i find a new one guess ill keep topping up when needed
would one of those fuel treatment bottles of crap help or is that just rubbish halfords junk
Posted : 24/02/2009 8:25 pm
02 tdci zetec focus for sale [url= http://www.singletrackworld.com/forum/topic/ford-focus-tdci-zetec-5-door-fs-2300-ono ]here[/url] that would be great for you 🙂
Posted : 24/02/2009 8:27 pm
An oil treatment type stuff might help for a bit.
Posted : 24/02/2009 8:29 pm
Possible problem with the cooling system. Could be a myriad of things. Check your rad, water pump, thermostat etc.
Posted : 24/02/2009 8:33 pm
rad coolant thermostat seems fine, ill just keep running im only after keeping it for the rest of the mot in july really,
i was meant to be buying that vectra from here for 800 but with all the snow i couldnt get down there ;-( so had to blob out , bugger bugger
racing ralph it looks pretty good but too much for me mate ;-)shame as i had a focus estate a few years back and really liked it
Posted : 24/02/2009 8:39 pm
second opinion for rings or have you altered the oil recently. Too thin and it will p155 through it.
Are you sure its not going into the water jacket (headgasket issue) look for emulsified oil or oil in the expansion chamber.
Posted : 24/02/2009 9:00 pm
Sounds knackered to me.
Its either leaking out ( you should see it) or being burned through the engine, then it could be rings, turbo, valve guides. Just worn out.
Posted : 24/02/2009 9:13 pm
Can you see any leaks or oil smell when the engine is hot?
Posted : 24/02/2009 9:16 pm
how about this: http://www.singletrackworld.com/forum/topic/fs-ot-vw-golf-10mths-mot-6-mths-tax-bargain?replies=8#post-152867
some half descent trails around Bristol too! 😉
Posted : 24/02/2009 9:28 pm
is there any margarine inside the oil cap? is there a puddle of oil under the car?
Posted : 24/02/2009 9:30 pm
aye mr nutt have some marg in the oil cap . tho im also told this is down to short journeys and enginge not getting hot enough to get rid of moisture and also getting left unused for long perionds. apparently pretty common in little old fiesta. dunno tho i thought it was a head gasket thing tbh. its not losing owt else tho or getting hot so **** knows
Posted : 24/02/2009 10:54 pm
Hmm, I reckon it could be the Bulb End's gone, you know...
Posted : 24/02/2009 10:55 pm
[center]bulorch[/center][*][list=1][list][code][/code]
What do all them things mean?
Posted : 24/02/2009 10:56 pm
any oil in the rad?
Posted : 24/02/2009 11:01 pm
 Nico
Valve guides usually produce blue smoke. I think worn rings, bores etc. will also make it smoky.
Posted : 24/02/2009 11:07 pm
no oil in rad alex and oil looks normal too. its a bit smokey on start up but clears as soon as a pull away
could be right fred 😉
Posted : 24/02/2009 11:14 pm
Maybe, it thinks that its being followed so needs to burn oil in an attempt to hide. I think some shops crossing the atlantic did that to avoid being shelled. I think their was some oil burning in the cruel sea?
Posted : 24/02/2009 11:17 pm
(Has visual mage of a newsagents, a Poundsaver and a Spar, floating on the waves, having empathy with prawns.)
Posted : 25/02/2009 12:24 am
Coz it's u****ed!
Posted : 25/02/2009 1:24 am
lol @ RudeBoy
Posted : 25/02/2009 1:36 am
Oil smoke stinks. You'll see it wafting about over other cars and making people in convertibles choke at traffic lights. At least, that's what happened with my car 🙂
Posted : 25/02/2009 9:31 am
the smoke smells a bit at start up but thats it. im hoping it holds out til after my wedding in oct cant be doing with more outgoings lol
Posted : 25/02/2009 9:40 am
Put diesel oil in it, thicker so should last a bit longer, did it on a panda I got for free and it still ran OK...
Posted : 25/02/2009 9:45 am
might be worth a try when i finish my current bottle 😉
Posted : 25/02/2009 9:46 am
You can also stick a mix on engine oil and gearbox oil to thicken it. AFAIR Wynns do an oil thickener which also helps it stay where it's supposed to
Posted : 25/02/2009 9:49 am
christ now its getting mad lol
Posted : 25/02/2009 9:54 am
What Fiesta is it? MkIII? I had this on my M reg 1.4 Fiesta and it turned out to be the front nearside brake caliper sticking on. Didn't seem to affect the mpg too much, but I was going through oil at a rate of knots. Normally the oil level didn't move on the dipstick - it was a great car, I used to do 520 miles/week in it and the oil never moved.
One day on the way to work, the pad on the sticking caliper went down to the metal, so had to get it changed quick sharp. Needed a new caliper and discs/pads replaced on the front, but then went back to using no discernible oil at all.
Posted : 25/02/2009 11:53 am
Possibly blocked breather, filler cap and I think there is a mesh one down the back of the engine. These block creating pressure in the block forcing oil up the bores, gets scrapped off and burnt. Can also cuase seals to leak eg crankshaft
The fact that it smokes on start up and clears could indicate worn valve stem & seals(head off job.
All those oil thickening trick are rubbish btw. Diesel oil has(or used to) have a detergent in it to scavenge any residue s from the bores, hence it gets very black & smelly. Can be used but needs changing more oftn or can cause damage.
Posted : 25/02/2009 11:54 am
how mad lol its a mk111 n reg 1.3
Posted : 25/02/2009 11:55 am
Cany say more.. its a ford
Posted : 25/02/2009 12:06 pm
Hey Trekster i am with you what a laugh looking at likely causes of oil consumption without even knowing what kind of engine we are dealing with !!!!!!!!
Those old fiesta engines were terrible for blocking breathers especially if they were used a lot for short journeys.
Has anyone actually thought as to wether the oil is being burnt or leaking out !!!!
Firestarter
Perhaps remove the rocker cover have a look inside if the top of the engine is completely gummed up? you could try chipping all the sludge away there should be some holes in the head which go down into the block make sure these are clear if there blocked all the crankcase pressure will go back up past the rings forcing the oil thats supposed to be in the engine into the combustion chamber and then out the exhaust ,although if it was burning that much oil i would expect you to leave a constant trail of smoke !!!!!and foul the spark plugs too.
If its that gummed up try some engine flush, then an oil change and use the cheapest mineral oil you can get 10/40. Those old engines were never designed for super thin super slipery oils
Jase
Posted : 25/02/2009 1:26 pm
Cheers Jase
Been 30 odd years since I played around with car engines but I do have a photo with me, my foreman and the first Fiesta when we did a course pre launch
At one point we put a rally cam in our demo sport which made it a real fun motor
Posted : 25/02/2009 10:01 pm
cheers all will have a look later 😉
Posted : 25/02/2009 10:25 pm
