Boring desktop PC q...
[Closed] Boring desktop PC question - Ubuntu install help pls
16 Users
I have an OLD desktop that I built up about 7 years ago. Problem I'm having is it was uselessly slow with Windows XP, so after a lot of success with Ubuntu 10.04 on my laptop I thought I'd give it a go on the desktop.
I'm using the same disc I installed Ubuntu on my laptop with, and have gone for a complete wipe of HDD and install Ubuntu as the only OS. It hangs at 5% during something to do with creating the new 'ext4' partition. Absolutely nothing I've done - including sending it to a PC specialist: they sent it back with a "sorry, can't figure it out" - has sorted this out and I'm now just wondering if it's more hassle than it's worth. I'm now stuck with an empty and unusable HDD, and at best can only run Ubuntu from the LiveCD, although even that hangs on a regular basis.
Any STW computer boffins got any ideas, before I bin it and start trawling eBay?
Posted : 23/01/2011 4:25 pm
 anjs
Have you created a new partion on the disk and has it been formated?
Posted : 23/01/2011 4:28 pm
I can't do anything with the disk. The ubuntu CD offered me the option of erasing all data and starting afresh, so I did that. That's when it stuck at 5%.
If I try to use GParted (or whatever it's called) via the LiveCD, it just hangs as well. The PC "specialists" apparently tried a different HDD in my machine, and that also froze.
Totally confused.
Posted : 23/01/2011 4:40 pm
Hold up.
Have you an external drive or usb stick - external storage basically?
Shove the Ubuntu CD in .. boot into live mode.. get everything important off the windows partition and put it onto the external storage (so you dont lose it).
Then try to delete all the non windows partitions using GParted. Just do this nothing more. Come back out. Go back into Ubuntu. You should now just have the Windoze NTFS or FAT32 partion and the rest of the disk a blank canvas. Use the auto partiting mode or specify the main / partition the size you want and a swap partition the same size as your ram. Hopefully it then writes these changes and works. If not download UBCD ultimate boot cd (google it). Burn it. Go to hard drive diagnostics tool. Find the one for your manufacturer and see what it says.
Posted : 28/01/2011 9:38 pm
Anyone know how to put it onto a machine with USB only?
I have an Acer One, running linpus, but want to go ububtu, i do have wireless access on it. So can download.
Line by line instructions would be good
Posted : 28/01/2011 9:42 pm
is it really as easy as it seems?
if so, ta!
Posted : 28/01/2011 9:48 pm
ye tis a piece of
Posted : 28/01/2011 9:50 pm
Conqueror
I have no way of getting access to the HDD content. Before I did the Ubuntu thing, I booted up Windows and copied all the files I wanted. Then went to install from the Ubuntu LiveCD and took the option to erase the whole HDD and then install Ubuntu on that "fresh" HDD. That's when it stalled at 5%.
The LiveCD 'Ubuntu-lite' will boot, but using GParted it stalls at 5% again. GParted shows no NTFS/FAT32 partition, just a boot partition and a swap partition (both 2 GB) and a 76 GB chunk of something else, maybe /ext3 -can't remember exactly, but sometimes it shows this and sometimes it just shows 76 GB of blank HDD. In addition to this, the LiveCD Ubuntu often just hangs for no reason as well.
After thinking about this for a while, would my desktop spec cause any issues? Specifically the 1 x 256MB and 1 x 512MB RAM stick combo I'm using. It worked OK in XP for a while, but I seem to remember reading that mixing different RAM isn't ideal.
Posted : 28/01/2011 10:39 pm
Put live cd in, mount the HD. Open terminal.
Go here section 4c
http://www.gentoo.org/doc/en/handbook/handbook-x86.xml?style=printable&full=1#book_part1_chap4
Just go as far as remove all partitions, this should remove any mess. Then try and install from cd again.
Posted : 28/01/2011 10:49 pm
I've had this problem.
Find and download the alternative install CD. I think that is what worked for me. Available [url= http://www.ubuntu.com/desktop/get-ubuntu/alternative-download#alternate ]here.[/url]
I'd go for 10.04LTS myself if you want to avoid future computer jiggery pokery, as it is supported for longer.
Posted : 28/01/2011 10:53 pm
You can check your memory configuration by running memtest86 which should be a boot option of your Ubuntu CD. I highly recommend doing this.
You could try taking one stick of memory out if this shows errors.
Posted : 28/01/2011 11:00 pm
I've tried the memtest86, and it shows no errors.
Posted : 28/01/2011 11:04 pm
Have you rebuilt your USB stick?
Posted : 29/01/2011 12:13 am
It's an OLD desktop on which the bios doesn't support boot-from-USB, so I just have the LiveCD. I know the LiveCD works cos I used it to install Ubuntu on my laptop.
Posted : 29/01/2011 12:20 am
how long ago? Create a new cd.
Posted : 29/01/2011 12:24 am
hmm you could try downlaoding the Ultimate boot CD and using a partition tool to create the partitions instead of booting into Ubuntu live to do it.
Ranish partition manager on UBCD is pretty decent, cant remember if it can create an EXT4 though.
If your memtest was ok there should be no issue with that memory setup. Sometimes voltages can cause problems if the power supply isnt supplying the correct voltage or its set too low or high in the BIOS. But you would expect memtest to complain if theres a problem.
I believe a Gparted dedicated ISO image also exists. But id probably get UBCD. It is only about 100mb download.
Posted : 29/01/2011 12:18 pm
My answer may not solve your problem, but I have to say there is some guff typed on this thread.
Posted : 29/01/2011 2:17 pm
Waderider what guff is that then?
Posted : 29/01/2011 2:56 pm
This is a good website so have a look.
Here everything you need to know about Linux or Linux related step by step guide.
[url= http://www.dedoimedo.com/computer_software.html#linux ]Linux etc[/url]
Simply click on any of the Linux icon and you get the guide.
Posted : 29/01/2011 3:08 pm
Right.
How old is old? Is it an IDE or SATA drive? If it's SATA, go into BIOS and look to either enable IDE compatibility mode or disable AHCI (it's the same thing, worded differently).
Again in BIOS, see if there's any 'boot sector protection' or 'virus protection' enabled and disable it if so.
See if you've an option to "reset configuration data" or "reset ESCD" in BIOS and select it. (this is a one-shot deal and will change back after you reboot, this is normal).
Look on the website for the manufacturer of your motherboard, see if there's an updated BIOS available.
+1 for 'try another CD' - download Ubuntu again, seems to be the common denominator here. Perhaps try a different version.
It's been a while, but are you forced to go for ext4 partitions? Try using ext3 instead?
Did it work back when you had Windows on it?
+1 also for PenDriveLinux - I use this a lot at the moment, I've got a heavily customised UBCD on a stick along with a LiveCD (persistent) Ubuntu install and various rescue tools. It's fantastic.
Posted : 29/01/2011 3:20 pm
(In the interests of balance / revenge, there's always nLite... http://www.nliteos.com/nlite.html 😀 )
Posted : 29/01/2011 3:22 pm
If you can install in non-graphical mode then if it's crashing you will see the crash dump, which might offer a clue.
Posted : 29/01/2011 4:01 pm
I forgot to mention - I've also tried Kubuntu and Mythbuntu LiveCDs. All hang when creating the partitions.
I'll try everyone's suggestions when I get home from work (a week on Monday). Thanks for your time so far.
Posted : 29/01/2011 5:06 pm
As an aside. I managed to install using USB only. Was a problem with the release version a few days ago, but fine and dandy now!
I started from the Ubuntulinux site
Posted : 09/02/2011 12:51 pm
How about using advanced partitioning and using ext3 instead?
99.99% of install problems I've had have been solved by using the alternate install CD with an ncurses interface.. but then most of them have been video card / X related.
Posted : 09/02/2011 12:54 pm
I think the PC in question has been binned by the repair shop chaps!
Posted : 09/02/2011 12:56 pm
Do an MD5 check of the downloaded ISO, and check the CD is burnt correctly.
I would also recommend using the Alternate CD too, due to the low specs of the PC.
Posted : 09/02/2011 12:57 pm
yes, the MD5SUM pinpointed the problem for me. But even that was easy to do.
Posted : 09/02/2011 12:59 pm
Yes, this is the binned PC. I'm sure each and every one of your suggestions [i]would[/i] have worked though 😐
Posted : 09/02/2011 1:05 pm
A different copy should sort you out.
BTW Ubuntu 10.10 seems better, I use it on a Pentium M laptop easily.
Kbuntu, Lbuntu or Ubuntu Mobile are lighter on resource too.
Posted : 09/02/2011 1:24 pm
+1 on the different CD
use gparted to delete existing partitions then reboot then try an ext3 install - writing over existing partitions is just a pain
Posted : 09/02/2011 2:29 pm
Try unbinning your PC then installing as we suggested
Posted : 09/02/2011 4:56 pm
As CharlieMungus says, USB tends to be better. It won't take almost any time at all and I never had any issues installing.
And go for the Meerkat 🙂
Posted : 09/02/2011 4:59 pm
You Linux guys really don't read threads before you reply, do you...!
Posted : 09/02/2011 6:23 pm
Because we're either useless geeks AKA waste of space or ignorants AKA normal folk.
Posted : 11/02/2011 10:47 pm
no, it's 'cos this BBsoftware isn't compatible with my version of UBU
Posted : 11/02/2011 10:55 pm
