BMW R80? weirdness.
[Closed] BMW R80? weirdness.
5 Users
It's been years since I had a motorbike but one of my colleagues regularly rides his Y reg BMW. Tonight it wouldn't run properly. It started, then died. It wouldn't restart despite turning over properly. No spark found when an HT cap was removed and shorted to the crankcase. Otherwise all electrics seemingly OK. Then weirdly, when he used the kill switch there was the biggest backfire! Scared me silly.
Can anyone suggest what was happening? Cheers, Ambrose
Posted : 02/12/2014 11:11 pm
Dodgy earth somewhere in the vicinity of the coils? I'm presuming it's an old y-reg r80 and so will have magnetos?
Posted : 02/12/2014 11:29 pm
coil is a known weak spot - will have to take the tank off , usually the plastic coating is split and moisture ingress leads to missfires and eventually total failure, although at that age it should have failed by now
Posted : 03/12/2014 12:17 am
That's what I wondered.
But why did it backfire? Charge dumped to the sparkplugs from the capacitor?
Posted : 03/12/2014 12:21 am
No exhaust full of fuel then it fired. Check the kill switch as well.
Posted : 03/12/2014 12:37 am
The kill switch backfire was an old trick, as said unburnt fuel.
Other than that, it's a BMW, it's supposed to break and do odd things
Posted : 03/12/2014 7:53 am
start here for R80 coil story http://redlegsrides.blogspot.co.uk/2008/07/joys-of-problem-diagnosis-on-airhead.html
Posted : 03/12/2014 9:54 am
