Blue tac stains on ...
[Closed] Blue tac stains on wall.......how to remove?
13 Users
 SiB
I know, not the most exciting of q's, sorry!
Daughter is moving out of her halls of residence on monday and she wants to get rid of blue tac stains on her room wall (painted emulsion) so she gets all of her deposit back............any ideas how/what with?
She asked me if wd40 would do the trick......?
Thanks
Posted : 11/07/2013 11:25 am
wd40
Posted : 11/07/2013 11:29 am
Rubbing it with a lump of blutack sometimes works as it pulls off any thats left on there. Depends on the wall and the mark but used to work for me at Uni
Posted : 11/07/2013 11:33 am
Firstly try rubbing fresh blu-tak on the "stains". They may not be a stain, more like a tiny bit of dried blu-tak left on there. Works quite well most of the time.
Lightly sand effected area.
Posted : 11/07/2013 12:01 pm
http://www.blutack.com/faq.html
How do I remove faint stains from the walls?
Citrus based stain remover is the best. If the walls have been painted sometime ago, they can become porous which will suck the oil out of Blu Tack. In this instance, you will need to clean with Sugar Soap and generally repaint the surface.
Bear in mind that [i]some [/i]wear and tear is expected. Whether the landlord accepts it is another matter, but if the deposit is protected (which it should be by law) then they'd have to demonstrate unacceptable damage.
Posted : 11/07/2013 1:08 pm
Nuke 'em from orbit. It's the only way.
Posted : 11/07/2013 1:39 pm
Blu-tak leaves a dark oily blob on emulsion and wallpaper. I've never tried it but I reckon a light degreaser like glass cleaner might do the trick, depending on how far the stain has penetrated.
Posted : 11/07/2013 3:23 pm
globalti - Member
😀 Hence wd40
Posted : 11/07/2013 3:42 pm
Tip-ex 😉
Posted : 11/07/2013 3:44 pm
WD40 will make a massive mark and prevent overpainting. If anything works I'd expect isopropyl alcohol and blotting, but not rubbing.
For goodness sake try it on an inconspicuous area first!
Posted : 11/07/2013 3:45 pm
WD40 is a light oil! As above, that will make the marks far worse!
Any volatile solvent will do; as suggested by GFS above, damp the stain then blot it in the hope that the solvent will disolve the stain and carry some of it away.
Posted : 11/07/2013 3:49 pm
Just over paint it. Pop down B&Q for a £1 tester pot. If you do a thin coat it'll pretty much blend out
Posted : 11/07/2013 3:53 pm
Worcester sauce and Newcastle Brown ale.
Posted : 11/07/2013 4:01 pm
Cover it with a poster 🙂
Posted : 11/07/2013 4:28 pm
