Dripping oil from front of my aaz 1.6td and burning on the exhaust! Yet no fog from the tail pipe?!? Any T25 td experts have a view. Lots of oil spewing out all over the fuse box in left hand corner of the engine bay (if you are standing at the back of the van, facing forwards, obviously).
Any clues?
Going to clean the engine and hen run it, to see where it's all coming from....
Update later
Possible leak somewhere in the air pipe between turbo and intercooler (or inlet manifold if no intercooler). Only needs a pin-prick hole to spew oil everywhere. Been there, done that! Try running the engine and moving a clean piece of white paper around the hose to see if you can spot the oil coming out.
Found the little blighter!!!
It's the main steel line between the sump and oil filter.
Phew!
Now I just need to buy the new line and fit it...
