Beginners guide to ...
[Closed] Beginners guide to nuclear power stations ?
As I understand it...
The fuel rods get hot.
Water gets circulated around them (the "cooling water" that everyone's talking about at the moment).
The water turns to steam and is used to drive a turbine.
The whole lot is contained in a sealed, or at least sealable, building.
If there's a water or steam leak, it's not a problem as it's all sealed inside the building.
I've obviously understood it wrong, going by the current problems in Japan, so which bit ?
Posted : 12/03/2011 8:17 am
I think that the tsunami knocked out the back-up diesel generators, thus preventing the pumps circulating the water from cooling the rods and potentially starting the meltdown process.
Either way I don't see this ending well...
Posted : 12/03/2011 8:27 am
China syndrome, anyone?
Hmm, doesn't look very good does it, especially with news reports bandying about the word 'meltdown', which isn't even remotely likely.
Shame about this scaremongering really as, despite being a beardedvegansinglespeedcycliststudent, I'm all for nuclear power (qualifier: as a medium-term alternative to fossil fuel-fired power stations).
Sorry, can't actually answer your question, but if unlooked for opinions weren't given at every opportunity, this wouldn't be Singletrack 😉
Posted : 12/03/2011 8:33 am
Cue TJ telling us all "Told you so...."
The hysterical media is getting more than a little tiresome.
EDIT: [url= http://live.reuters.com/Event/Japan_earthquake2 ]This doesn't sound too good actually....[/url]
Posted : 12/03/2011 8:42 am
So the back up generators have been flooded and the water is no longer circulating.
The steam pressure rises until a pipe bursts, or more likely, a pressure relief valve opens, the steam escapes in to the much larger volume of the containment building.
Where's the problem ?
Look for Boiling Water Reactor on t'internet.
As far as I understand it, nothing's "going wrong" as it were, apart from the bleeding obvious. There's a chain of safety measures and each "newsflash" we hear about is just one more step along the chain. They're depressurising now so they can use the low-pressure cooling system. I think they possibly knew they would have to go this far along the chain quite some time ago, hence the urgent need for coolant that we've been hearing about on the news.
Posted : 12/03/2011 8:47 am
from the Guardian
"7.52am: Japanese media reporting that explosion heard at TEPCO's Fukushima Daiichi plant around 0630 GMT - more soon"
Posted : 12/03/2011 8:57 am
From Reuters:
Japan Nuclear Safety Agency: has heard explosion was not at reactor
Phew (maybe)
Posted : 12/03/2011 8:59 am
Until the media stops being hysterical we will not know what is happening.
But the fact is water has wrecked a lot of stuff, water in electrics is not good.Think we all understand that bit.
The ground has opened up and swallowed whole parts of the country, doubt if it discriminates against a nuclear plant or bedding plants!!
One thing is certain, Japan and NZ will be rebuilt before Haiti ❗
Posted : 12/03/2011 9:10 am
Well damn. You know when you really, [i]really[/i] wish you'd been right 🙁
[url= http://live.reuters.com/Event/Japan_earthquake2 ]http://live.reuters.com/Event/Japan_earthquake2[/url]
Seems #1 is pretty much done for, and #2-#5 are experiencing the same issues but a few hours behind.
Posted : 12/03/2011 9:52 am
It's looking pretty ****ed up
Posted : 12/03/2011 9:55 am
BBC is showing footage of what looks like a nuclear powerplant collapsing... maybe exploding.. oh wait a minute they said explosion...
zokes - Member
Told ya so
Gotta love TJ! Hahahahaaa!
Posted : 12/03/2011 9:57 am
 Ewan
Well the news is pretty convinced it's the reactor that exploded. There's some before/after film of a big square building, aka the containment building blowing itself to bits. It's a pressurised water reactor, so if you can't stick the control rods in or cool it down, I can't see why it wouldn't be the reactor that exploded....
Posted : 12/03/2011 10:20 am
it looked like a direct hit from a laser guided bomb down the ventilation shaft. the expert on the bbc was still talking about getting the pumps working again, yeah what pumps.
Posted : 12/03/2011 10:30 am
Gotta love TJ!
Do we have to?
Posted : 12/03/2011 10:32 am
Yes you do! Just don't push back...
Posted : 12/03/2011 10:35 am
 Olly
a so called "melt down" should be impossible, if it isnt, someone is going to have to answer some questions with some damn good answers.
In Chernobyl, the rods were lowered into the reactor, in order to make the heat. when the control systems failed, the weight of the rods, held them in the reactor under gravity, and they could be pulled out.
since chernobyl, its been flipped.
the rods default position (due to gravity mainly) is OUT, not IN.
the rods have to be actively held into the core, and if anything goes wiggy, they should fall out due to gravity.
a high tech dead mans handle arrangement.
if they pump that moves the water around the reactor has failed, no one is getting power ANYWAY, so they will just shut it down and it will begin to cool.
surely?!
i would IMAGINE, if the station is "gravity fed", the UN and other such "masters of the universe for the forces of good" are going to have a SHITFIT, though this is just extrapolation.
Posted : 12/03/2011 10:37 am
Good old beeb
http://news.bbc.co.uk/1/shared/spl/hi/sci_nat/05/nuclear_fuel/html/reactor.stm
Reports of the explosion though are still sketchy.
Posted : 12/03/2011 10:38 am
The liquid that circulates round the reactor does not turn to gas (it isn't always water) - it passes through a heat exchanger which transfers the heat to the water which vaporises to drives the turbines.
Posted : 12/03/2011 10:40 am
 Olly
and that! Chiefgrooveguru.
any vented steam, wont be radioactive,
coolant is normally pulled from the sea, and put back into the sea ANYWAY.
quite often to the distress of the environ-mentalists, as the warmer water means we are getting tropical sealife in the small lagoon off our north sea reactors
its going to be pretty unlikely (fingers crossed) that the heat transfer fluids leak.
Posted : 12/03/2011 10:45 am
My guess is the secondary coolant system has over-pressurised and exploded because the backup jenny pumps are flooded. It's a bit radioactive, but not that much to worry about.
The next problem is the primary coolant. The worry is that even with the rods dropped and the reaction slowed right down, the fuel rods warp and melt, dumping pellets on the floor and making the reactor un-recoverable. In essence: Three Mile Island mark II.
I think China Syndrome is where the reactor heat slowly melt through the floor and just keeps going until it hits the mantle.
Posted : 12/03/2011 10:55 am
Posted : 12/03/2011 10:59 am
Gulp 😯 http://www.bbc.co.uk/news/world-asia-pacific-12721498
Just for you TJ, here's a picture of a man holding some Uranium and not dying
Posted : 12/03/2011 11:02 am
That does look a big bang!
and here he is relaxing at home with his children... 😆
Posted : 12/03/2011 11:08 am
They need to get Homer in......mmmmm uranium
"This is starting to look a lot like Chernobyl" Walt Patterson, an associate fellow with Chatham House, has told the BBC after seeing pictures of the explosion at the Fukushima-Daiichi nuclear plant. "The nuclear agency says that they have detected caesium and iodine outside the unit, which certainly indicates fuel melting at the very least," he says. "Once you have melting fuel coming into contact with water, that would almost certainly be the cause of the explosion."
Posted : 12/03/2011 11:13 am
The man is holding unused fuel pellets - not especially dangerous. They make these just down the road from me, and I'm not worried. Once the uranium is in a reactor and the chain reaction starts, you get lots of nasty fission products - these are very radioactive, hence all the fuss about storage of spent fuel rods we're having at the moment - highly radioactive for thousands of years.
Edit: I do wonder about the wisdom of putting lots of nuclear reactors in a highly active earthquake zone.
Posted : 12/03/2011 11:14 am
Just heard an "expert" on the Beeb talking about how they have shutdown the fusion reaction...
Err - maybe he meant fission????
Rachel
Posted : 12/03/2011 11:18 am
Their secret's out!
Joking aside, this situation, as reported by STW (I can't get any usful websites as I'm at work), sounds properly awful. Keep us posted, gang.
Posted : 12/03/2011 11:25 am
Outer building shell is usually designed to "fail" before the really important containment stuff inside is put at risk of damage - the big outside building is primarily there to keep the weather away from the electrical/mechanical stuff inside of the building. Blast looked to be gas-driven - a high velocity flash of burning gas (hydrogen ?), then lots of dust and debris as the building shell disintegrates, but then no flame or smoke (so little or no fire).
Posted : 12/03/2011 11:28 am
I suspect that the leaking gas is marginally radioactive; but certainly no more a threat than the several thousand nuclear weapons the rest of the world has tested over the last 65 years.
Posted : 12/03/2011 12:00 pm
Analysts say a meltdown would not necessarily lead to a major disaster because light-water reactors would not explode even if they overheated.
But Walt Patterson, of the London research institute Chatham House, said "this is starting to look a lot like Chernobyl".
This [url= http://www.waltpatterson.org/nuclearpower.htm ]Walt Patterson[/url] not a fan of the Nuclear Industry really
Posted : 12/03/2011 12:01 pm
 Olly
no Walt, not really
Posted : 12/03/2011 12:30 pm
no Walt, not really
OK, Three Mile Island then?
Posted : 12/03/2011 12:44 pm
 Olly
yep, more likely to be more accurate by the looks of things, but 3 mile island didnt develop into chernobyl, and i doubt this will/can too.
Posted : 12/03/2011 12:51 pm
 j_me
China will be fine. South Georgia and the South Sandwich Islands are pretty much toast though.
Posted : 12/03/2011 12:52 pm
Professor Robin Grimes - imperial college London, says it's almost certainly not that bad.
Posted : 12/03/2011 1:03 pm
Tom Logan of the institute of studies said "aye it's a right balls up is this. I can see reactor #1 going off like a giant nuclear cock"
Posted : 12/03/2011 1:17 pm
aah, Tom Logan, i am familiar with his essays, truly a wise man,
Posted : 12/03/2011 1:22 pm
Posted : 12/03/2011 1:27 pm
Read [url= http://www.world-nuclear-news.org/RS_Battle_to_stabilise_earthquake_reactors_1203111.html ]this[/url] for a less scare mongering, more technical description of whats going on.
Posted : 12/03/2011 1:32 pm
Surely as soon as it looks even remotely like it's going to go breasts skywards they'll just dump the control rods into the reactor chamber and the problem is solved no?
Posted : 12/03/2011 1:52 pm
Or if you read the papers or watch TV,
ZOMG NUCLEAR REACTORZ R EXPLODIGN IN JAPAN ITS CHERNOBBLE ALL OVR AGN WONT SOMEINE THINK OV TEH CHILDREN?!
I'm really, really starting to hate our media services. Bunch of scaremongering, lying bastards.
Posted : 12/03/2011 1:58 pm
I think if I lived near a reactor that had just blown up like that one, I wouldn't be staying near it saying it's all media lies.
Posted : 12/03/2011 2:05 pm
Looking further ahead, if it does all go tits up, which way is the wind blowing? I remember a load of radiation being dumped all over the world and Scotland when Chernobyl went up.
And if there is another powerful aftershock in that area, would it damage the thing even more?
Posted : 12/03/2011 2:06 pm
They have already done that when the quake struck
Full Tech info [url= http://www.tepco.co.jp/en/index-e.html ]HERE These are the statements from The Operators[/url]
As it starts to cool you need to add some water and balance all the pressures while everything chills out.
As the Aux equipment is a bit buggered this is harder. Reactors are designed with failsafes and secondary containments etc. If pressure is released then it will go into the secondary.
Posted : 12/03/2011 2:07 pm
A friend who lives 180k away has been advised by a nuclear physicist friend, if the winds continue in the direction they are blowing and if the core was not breached (as it now appears) so possibly only a steam explosion with a localized and relatively small radioactivity, then it is fine to stay where he is. If it does turn out that there has been a core breach (which appears unlikely atm), that is a VERY different situation and he should move 500 kilometers away.
Posted : 12/03/2011 2:17 pm
The reactors all automatically shut down when the earthquake hit yesterday, the issue has been that the reactor core is still hot and needs to be cooled (by water) and the coolant systems and backups failed.
Before anyone starts thinking that this is another Chernobyl you need to remember that that power plant had no containment structure around the reactor (no one in the west or japan builds reactors like this because it is fundamentally very dangerous, well, actually its mind bendingly stupid) and the graphite core actually caught fire and exploded, destroying the whole reactor. From what I can see of the images and what the experts seem to be saying is that the Japanese reactor looks to be still ok (ie, intact and not leaking as otherwise you'd see a very large release of radioactive material) but its outer building that surrounds the containment building has been badly damaged by a hydrogen/oxygen gas explosion when they were trying to vent pressurised water/steam from the reactor coolant circuit.
Still, not good though.
[url] http://www3.nhk.or.jp/daily/english/12_54.html [/url]
Posted : 12/03/2011 2:19 pm
Mind you, the Japs should be used to being nuked by now..... 😉
Posted : 12/03/2011 2:35 pm
Is his friend's name Pike?
Posted : 12/03/2011 3:01 pm
[url= http://www.scientificamerican.com/article.cfm?id=coal-ash-is-more-radioactive-than-nuclear-waste ]Coal ash more radioactive than nuclear waste![/url]
Posted : 12/03/2011 3:09 pm
A friend of mine, Kazuko in Sapporo just emailed me. She reckons ????????????????????????????????????????????????
I don't know what it means, but the exclamation marks are a bit worrying.
Posted : 12/03/2011 3:24 pm
Basically she's alright because of where she's located.
Posted : 12/03/2011 3:27 pm
Yes, a bit of a downer,this one.
In terms of failure scenarios, it's more like Three Mile Island than Chernobyl, with a loss of coolant in a Boiling Water Reactor. The real issue for the Japanese reactors is that the seismic event (earthquake) and the flooding event (tsunami) are linked, ie in Japan they occur together. It's relatively straightforward to cope with either one separately.
The IAEA website http://www.IAEA.org has reasonably good info, albeit a few hours behind the media.
Hope it turns out ok, not a situation I'd like to be in
Posted : 12/03/2011 4:28 pm
Posted : 12/03/2011 5:15 pm
its a cld war era reactor, everything from that era broke down, screw you guys i'm getting a radioactive umbrella and a pvc gimp suit with gas mask....
wait wrong situation.
Just a very tricky spot for them to be in, im totoal 1 worker has been been killed ( by explosion but he had traces of radiation at 134 rads?
3 people have been taking to a hospital with radioactive poisoning.
Posted : 12/03/2011 5:33 pm
They are trying to save the reactor - they could just let all the water out of the core, which would stop all the pressure build up and explosions (they are having electrical problems, thus the pumps are struggling to keep enough water in the core - so just like a car, it is blowing off steam due to overheating.
If they turned off *all* of the water, then the core would melt (completely safely, inside the containment vessel) but then the reactor would be totally wrecked and unusable. They're trying to cool it down gently so that they can use it again in the future.
It's a boiling water reactor, so it's supposed to have steam in the top part of the core - think of it like a constantly boiling kettle that they collect the steam from to run turbines for power generation. You have to keep adding water or it'll boil dry. If it boils dry you could damage the kettle.
What seems to be happening here is it's nearly boiling dry, some of the fuel elements are breaking open in the heat and these exposed fuel elements are reacting with the water, releasing hydrogen - which then exploded as they tried to release it.
If it ever gets to a serious danger point they can just drain out all the coolant and let it all melt with no danger of gasses building up that could cause blowouts, at the cost of wrecking the reactor totally.
Posted : 13/03/2011 9:12 am
If it isn't exciting they don't get paid, so no incentive to be accurate
Posted : 13/03/2011 9:25 am
I would never defend the UK press (mostly a bunch of clowns) but my friend who lives 180k away has been told there have been changes for the worse. They are unclear of what is happening so his wife and child have now moved further away. He is staying at the moment but ready to go.
Even if it doesn't go into full meltdown it is still being very destructive to a lot of people especially as the earthquake was so damaging. Standard rules do not apply.
Posted : 13/03/2011 12:07 pm
it seems that automatic "tripped" shut down in the event of an earth quake might no be the best of safety features. Having to the rely on back up generators has completely failed. Some kind of gradual shut down, keep them running at a level where they are self supporting, until they can be switched off safely might be a better course of action. Though building a nuclear reactor in a known earthquake zone may not be the wisest of decisions.
Posted : 13/03/2011 12:35 pm
bassspine - Member
I trust them more than I trust people with a financial interest in the nuclear power industry.
We've got the second worst nuclear accident in history and still, despite the failure of primary and secondary cooling systems and the consequences thereof, we are still being told that nuclear power is safe and controllable.
Given that this has happened in one of the most advanced and organised countries on earth, it doesn't bode well for a fully nuclear powered future, does it?
Sadly, human involvement in a system is a guarantee that the system has the potential to fail.
Combined with the human propensity to refuse to learn from history, an extremely serious nuclear accident is inevitable at some point.
Which is precisely what opponents of nuclear power have been saying for years.
Posted : 13/03/2011 12:39 pm
I was down the road when this went up in smoke during a thunderstorm a few years back.
Sizewell powerstation, just up the road from that there London village, and for some reason it didn't even make the news which leads to one of two conclusions.
1) It was assumed that the locals had enough in common with Norfolk and their cousins not to notice a few extra apendages.
2) The powers that be covered it up.
*doffs tinfoil hat*
Posted : 13/03/2011 1:00 pm
RustySpanner,
It was cutting edge 30+ years back, modern designs always learn from the errors of the past, since Chernoble they no longer use gravity fed reactors, since Windscale the filtration systems have been altered, and this Japanese reactors 'flaw' of relying on the cooling water has been solved on the current reactors by making them passively cooled.
If you look at the statistics then by kWh nuclear is by far and away the safest power source we've ever used, ironically hydro comes out by far and away the most dangerous.
Posted : 13/03/2011 1:05 pm
Nope. It's a closed system. The water is converted to steam in the reactor core. This steam drives a turbine. It is then converted back to water in a condenser fed by external cold water, then reintroduced to the reactor core to start over again.
I can safely say that we're all glad you're not in charge. You seem to be suggesting that a meltdown situation wouldn't be that bad. Google 'China syndrome'. Whilst melted fuel would hardly reach the opposite side of the globe, the reactor would not be able to contain the fuel as you suggest. It would burn through the base of the reactor and end up in the earth below, contaminating water tables and goodness knows what else.
[url= http://en.wikipedia.org/wiki/Kyshtym_Disaster ]Not quite[/url], Captain Panic. A lot of guff is being spouted about this across the internet and via the news networks. Don't just take it as gospel. A bit of background reading goes a long way. What's happening at the moment is worst-case scenario from a financial viewpoint. The Fukushima I plant will probably never operate again. At the very least, the affected reactors won't.
I'm not saying it isn't bad, cos it clearly is. It's nothing like a Chernobyl though. 3 Mile Island is the best comparison.
Posted : 13/03/2011 1:17 pm
Is it dangerous and out of control, then?
Posted : 13/03/2011 1:54 pm
Yes and after Chernobyl and Three Mile Island, this is the biggest commercial nuclear incident we've yet been told about.
Ok.
I'll put it another way:
Every single system designed by human beings, thus far, has, at some point, failed.
Humans make mistakes - it's in our nature.
Up until the 20th century, the consequences of these mistakes and the subsequent system failures have been on a very small scale.
With nuclear power however, the consequences of our mistakes obviously have a far greater impact and significance, one that has the potential to fundamentally change the relationship between our species and our planet.
So, unless the humans now designing power station safety systems are fundamentally different from every other human that has ever existed, there will be more serious nuclear incidents.
It is inevitable.
And that is why, despite all the reassurances in the world, many people are very, very suspicious about nuclear power.
Posted : 13/03/2011 2:07 pm
 poly
Rusty Spanner,
There's a good book called [url= http://www.amazon.co.uk/gp/product/0753515539/ref=as_li_tf_tl?ie=UTF8&tag=polwart-21&linkCode=as2&camp=1634&creative=6738&creativeASIN=0753515539 ]"Risk: the science and politics of fear"[/url] by Dan Gardner which you might enjoy - it turns on its head scary kneejerk reactions to incidents like this.
Posted : 13/03/2011 2:44 pm
poly, that looks like a really good read.
More info [url= http://www.dangardner.ca/index.php/books/item/16-risk-the-science-and-politics-of-fear ]here [/url]if anyone wants to read more about it.
Posted : 13/03/2011 6:50 pm
[i]If you look at the statistics then by kWh nuclear is by far and away the safest power source we've ever used, ironically hydro comes out by far and away the most dangerous. [/i]
How many people have died from hydro power stations exploding?
Posted : 13/03/2011 7:25 pm
chernobly UN report claims 9000 cancer related deaths as aresult of the radiation. Greeenpeace 250,000 and i think the use of the term per KWh may be very important in that unreferenced statistics quoted above
i was wondering how many died as a result of solar panels collecting electricity hence my belief that the kwh is the critical - any chance of a source and actuall numbers?
Coal and gas are presumably high due to themining of the raw material rather than the generation per se I assume hence mis leading??
Posted : 13/03/2011 7:37 pm
There are many ways that people can be killed in an industrial setting that don't involve explosions. Given that the total death toll from Chernobyl is estimated at about 60 it's not actually that big a claim. The death toll from Piper Alpha was three times that, but I've never heard of that being a reason to stop exploring or producing oil and gas.
Posted : 13/03/2011 7:39 pm
Posted : 13/03/2011 7:45 pm
Well whatever happens, tomorrow night after work I'm having a 'nuclear supper'.
Fission chips.
Posted : 13/03/2011 7:58 pm
Could try this:
Posted : 13/03/2011 8:03 pm
I was also surprised when I read that hydro power has the greatest number of fatalities per kWh, but then I read about several nasty accidents, eg one in Russia where about 70 people were killed due to a phenomenon known as "water hammer", caused by blockage of one of the inlet ducts (see link to BBC website):
http://news.bbc.co.uk/1/hi/8216138.stm
From memory, one of the reasons why the death toll was so high was that some visitors were having a plant tour at the same time.
Also, haven't heard much about the Japanese oil refinery that seemed to be burning uncontrollably just after the quake / tsunami.
Back to the Japanese reactors, the US Nuclear Energy Institute has a lot of details on their website, eg:
http://www.nei.org/resourcesandstats/documentlibrary/safetyandsecurity/factsheet/radiation-and-the-japanese-nuclear-reactors/
And a nice cutaway picture of the Fukushima Daiichi Unit 1 station
Posted : 13/03/2011 8:28 pm
Page 1 / 15
