Bathroom Flooring O...
[Closed] Bathroom Flooring Options
13 Users
Tiles appear to be out as a flooring option for my ensuite. The chipboard flooring is just too bouncy. What looks similar to tiles but is more flexible? We don't want cheap vinyl or a wet room style floor. We haven't got underfloor heating to worry about.
Posted : 14/03/2016 5:38 pm
Have you considered cork tiles? We have a click lock system (floating) in the ensuite and glue down tiles in the main bathroom. Our subfloor is not the best and they seem to cope with it fine.
Posted : 14/03/2016 6:13 pm
You could go for a bathroom suitlable laminate or engineered wood. Or if you are feeling funky...
[url= http://www.slip-not.co.uk/productdetail/Heavy-Duty-Rubber-Gym-Flooring-Studded-Penny-Pattern ]rubber![/url]
[url= http://www.jaymart.net/prialpas.php ]a supplier I have used before...for er...rubber[/url]
Posted : 14/03/2016 6:22 pm
 colp
Replace the chipboard with 18mm marine ply or backer boards, then tile.
Posted : 14/03/2016 6:29 pm
No to cork tiles. Its not the 80's! (Sorry)
Cannot remove the ply as the boards run under walls. It took me two days with a circular saw and multitool just getting access to wiring elsewhere.
Bathroom laminate sounds like an option. Does anyone have any experience of this in terms of water resistance?
Posted : 14/03/2016 6:35 pm
Rather than cheap vinyl (i.e. one big roll), get expensive vinyl - like Karndean or Amtico (and plenty of other imitations for the budget-conscious)? There are some good options for bathroom floors that you can glue direct to the chipboard, fit nice and close to pans, sinks, shower trays etc.
Posted : 14/03/2016 7:13 pm
I fitted some Harvey Maria rubber tiles in the bathroom a few weeks ago - [url= http://www.harveymaria.co.uk/Floor-Range/Rubber ]linky[/url].
(Anyone wanting to do a loo with "peppermint cream", I have eight tiles left (2m2) that can be had for a charitable donation)
Posted : 14/03/2016 7:32 pm
I've just finished treating exactly this problem with cement based backer boards (I used Hardie Backer, other brands are available). In my case I lifted a few floorboards, packed the joists to stop them flexing then stuck the backer boards down to the wood with tile adhesive, then screwed through. Tile on top as normal.
Posted : 14/03/2016 8:14 pm
Karndean/Amtico can look very good, simple to lay well DIy as well
Posted : 14/03/2016 8:44 pm
 aP
Were have Marmoleum in ours. British made, low VOC, warm to touch, don't show the dirt...
Posted : 14/03/2016 9:11 pm
Cheapest is a roll of cushionfloor vinyl. Can be OK. I also fit Karndean. But carpet is my favourite. Much cosier.
Posted : 14/03/2016 11:17 pm
for that authentic 70's musty pissy smell. lovely.
Posted : 15/03/2016 9:18 am
slate effect rubber tiles, not as funky as the studded ones but hard wearing and non slip
Posted : 15/03/2016 10:47 am
Karndean or Amtico. We had a wood strip finish over a new marine ply base screwed to the existing floor and it's lovely. cleans up well and is reasonably warm underfoot unlike tiles.
Posted : 15/03/2016 10:48 am
You could try a product called aquastep, it is a resin/plastic version of laminate flooring so easy to fit and feels good under foot. Comes in a few different finishes.
Posted : 15/03/2016 10:59 am
