Bad form push-ups
[Closed] Bad form push-ups
10 Users
where your elbows flare out so forearms aren't locked in vertical position.
Are they really so bad?
Feels a more natural way to do them to me, a bit easier, and have been making progress with them alongside inverted rows and seated dips. Also feels slightly better on my wrists as don't need to lean forward so much.
Posted : 14/11/2016 7:21 pm
Mix them up, narrow, wide, thumbs together, hold in upright position, halfway, fully lowered fast slow, I used press up bars for a while until my son nicked them,ignore the purists.
Posted : 14/11/2016 7:51 pm
Arm position doesn't matter.
Core strong, don't let the hips drop, chin and chest to floor are the only things that matter
Posted : 14/11/2016 7:53 pm
Try a session of 60 second plank with 30 seconds of press ups.
Posted : 14/11/2016 7:54 pm
A quick google suggests elbows in is possibly better for the shoulder joint? Never thought about it before, but I've always done it that way. Don't see how it would hurt your wrists though unless you had a mobility issue. I would say just do it whichever way feels best though, your body is pretty good at telling you when something ain't right!
I wouldn't ever do an exercise variation just because it was easier & it let me do more reps though, that makes no sense if you're trying to get stronger.
Thanks will try suggestions plus a bit more persistence.
Some of them say that it's bad for the elbow joint for elbows to flare out, but it doesn't feel bad at all to me. Feels more of a strain on [s]upper arms [/s] (fact checking.... please wait...) lower arm muscles with elbows in.
Definitely need to mix it up a bit.
Posted : 14/11/2016 8:06 pm
Posted : 14/11/2016 8:09 pm
Think I've got too much jacket potato, tuna, topped with banana custard in my belly for that right now.
Posted : 14/11/2016 8:12 pm
With regard to mixing up the different forms of push ups goes, any recommendations for that?
I'm currently aiming to do these exercises (as mentioned in #1) at least twice (mostly) or three times a week. Currently using a DIY push-up bar, my max with regular push up currently at 16,16,20,20,16.
Would trying to do a different form for each of those sets be a good idea?
would need to drop down the reps for the forms I'm not used to. Don't suggest archer push ups to me at this stage, not strong enough.
Posted : 14/11/2016 8:32 pm
Try moving on to press ups with slightly elevated feet next 💡
Try proper dips as well maybe, doing them on a bench is meant to be bad for your shoulders.
Posted : 14/11/2016 8:40 pm
Good guide to proper form, although you'll very rarely see it in a normal gym
https://gmb.io/push-up/
Posted : 14/11/2016 10:53 pm
those push up platforms that rotate as pretty good - although maybe not as robust as they could be. Makes the movement feel much more 'progressive' - or something like that.
Posted : 14/11/2016 10:56 pm
Blimey I've been doing it all wrong all these years - I make a T with my arms. Think I've tried that elbows straight back style but really struggle - time to man up and do it properly then.
Posted : 15/11/2016 12:51 am
It's much harder, but your shoulder is much better supported by the Lats etc in that position, so it's a stronger base to work from and less likely to cause injury.
Posted : 15/11/2016 10:13 am
 Keva
try hindu press ups
Posted : 15/11/2016 10:34 am
Tell you what, Diamond push ups make correct form quite easy in comparison.
Posted : 17/11/2016 8:46 pm
ouch!
Posted : 17/11/2016 9:39 pm
