Rather than have two dishes are these two satellites (19.2E 28.2E)
close enough for a dual lnb setup?
by dual LNB do you mean 1 LNB with two o/p's or two separate LNB fitments?
If the second it is possible.
Never seen it on a standard sky dish but have on larger dishes.
Sorry, yes, two separate lnbs. When you say larger dishes do you have an idea what the minimum size might need to be? Think mine is only 50 to 60cm.
sorry I might have missed something..
those two sats are 9 degrees apart are they not?
I would be very surprised if one dish could get both, and would be fascinated to know how its done if it is possible on one dish!
It may work with a smaller dish though i've never seen it tried, i've only seen it with 80cm plus dishes.
You might get it to work with a smaller dish but I imagine you would have to be very accurate with the positioning of each LNB.
Have a google, there is a fair bit of info out there on how to do it.
well it looks like it can be done.. there you go.
You'll have to shift your dish a bit though!!
Yes it can be done
I used to do lots with a 6° spread
There's some DIY stuff here - some a bit more professional than others
http://www.satcure.co.uk/tech/dish_xtra_LNB.htm
Great! Thanks Jota. Since toying with the idea I've now found that to get to Astra 2 I've got a row of oak trees to penetrate. Doh!
