Anyone recommend an...
[Closed] Anyone recommend an oscilloscope?
Say for up to a few hundred quid? Daughter is playing around with arduinos and simple circuitry at the moment, and although you can do a fair amount with a multimeter a scope is more useful for seeing what is going on. Probably no real need to be able to see stuff up at clock speed (8-20MHz I think), more useful for seeing what is going on with outputs or signals in the analogue sections
I've seen various USB devices that require a computer and would be fine but there does also seem to be some stand alone machines in that price range. Looking for two channel and if it comes with a 3rd channel as a trigger all the better
Any tinkerers out there with suggestions?
thanks
Posted : 24/08/2021 7:52 pm
I'm no expert, being a mechanical person not electronics, but I use USB picoscopes a lot at work and they seem pretty good. Prices start at around £100. You can never have too many channels!
Posted : 24/08/2021 7:59 pm
Agree about the Pico stuff. We also use it (temperature data logger) and it's well made and works well. I've been thinking about getting a scope for the same reason as the OP and Pico will be top of the list.
Edit: Just to say, obviously, the USB scopes aren't as fast as a 'real' scope, but for this sort of thing should be fine.
Posted : 24/08/2021 8:10 pm
The pico stuff is looking very nice indeed.  Up my budget a little and I can get what looks like 8 channel digital and 2 channel analogue which would be perfect.   I'll keep hunting though
The last oscilloscope I owned was a Solartron thing.  2 channel, valve, could just about manage 100kHz at a push 🙂
Posted : 24/08/2021 8:16 pm
I've got a hantec something or other 100mhz. Does me for most electronic stuff in the non high speed world of interfacing sensors etc to muC.
Posted : 24/08/2021 8:18 pm
I’ve got a hantec something or other
Looks good as well and might be slightly more available, thanks
Posted : 24/08/2021 9:00 pm
I have a Bitscope micro:
http://bitscope.com/product/BS05/
As long as you don't mind driving it with a computer, it's pretty good for mixed signal stuff.
Posted : 24/08/2021 9:01 pm
Sorry I couldn't get to find the exact model. Found a link. This isn't the exact one but it's pretty similar specs but mine is a few years old.
https://tinyurl.com/e64nxmvk
Personally I prefer a separate unit (I did try a Pico once but only for an afternoon). I found having knobs to twiddle was nicer to work with than using a mouse. Plus I was frequently programming so didn't want to be swapping windows.
Posted : 24/08/2021 9:19 pm
Good point on the knobs and messing with windows, especially when debugging code.  Not sure I want another big bit of kit in the house though but I'll add that to the mix thanks
Posted : 24/08/2021 9:30 pm
Bitscope is an alternative to the Pico USB scopes, and a little cheaper as well. I think it also comes with bits to allow you to write your own software for it too...
Posted : 24/08/2021 10:09 pm
Serves me right for not updating before responding... it's already been mentioned!
Posted : 24/08/2021 10:10 pm
Just thinking... it your daughter is playing about with micros, then unless you are only doing something analogue then you might be better off with something that also includes a logic analyser as it'll give you more channels when looking at digital signals.
It's that sort of functionality which the Bitscope is really good at.
Posted : 24/08/2021 10:18 pm
Yep, I spotted that the picoscope also offers that in it's mso versions.  My problem with the bitscope is that it doesn't look very robust, but I do have a habit of allowing scope drift (ahem) and buying something a lot more than I need
Posted : 24/08/2021 10:23 pm
I have a Hantek DSO2C10 which cost me £190. Very capable and easy to use. I restore ZX81s with it
Posted : 24/08/2021 10:31 pm
My problem with the bitscope is that it doesn’t look very robust, but I do have a habit of allowing scope drift (ahem) and buying something a lot more than I need
The Bitscopes are more robust than they look. In part because they are very small. I have very expensive scopes to play with at work if I need to twiddle knobs.
When I bought my bitscope, they had much better cross platform support (i.e. they don't just run on windows) than the competition.
They are not super accurate/quiet, but I use them to play with microcontrollers and the like where you may want to monitor digital signals along with analogue outputs. For a kid getting into this stuff, I would imagine they would be more than adequate.
Posted : 24/08/2021 10:46 pm
Recommended what you own - I have a Fluke123 industrial 'scope, portable and rugged enough for shop floors but probably overkill and over budget but they do hold their value well if you can bag a cheap one?
Posted : 24/08/2021 11:41 pm
Would love a Fluke123 but that is quite firmly over budget 🙂
Posted : 25/08/2021 12:02 am
 xora
Hantek DSO5102P
Posted : 25/08/2021 2:47 am
Nice little Tektronix DSO should do the job:
https://www.ebay.co.uk/itm/Tektronix-TDS210-60MHz-Oscilloscope-2-probes-/304112567802/
Posted : 25/08/2021 8:10 am
The 100MHz version of that Tektronix scope was my goto everyday scope at work for about 10years 🙂
I could have used more complex kit but it was so simple for most jobs it was perfect.
Posted : 25/08/2021 8:47 am
That Tektronix has me feeling all nostalgic now although I only ever used older models of their stuff. Too much choice now but good choice
Posted : 25/08/2021 2:54 pm
