Anyone managed to r...
[Closed] Anyone managed to remove scratches from DVDs?
I mean successfully.. ?
Posted : 03/08/2013 9:08 am
Yep, bought a SkipDr. No luck with toothpaste etc
Posted : 03/08/2013 9:11 am
Buy a new copy.
HTH.
You still use CD's?
Posted : 03/08/2013 9:13 am
You still use CD's?
Apparently not.
Posted : 03/08/2013 9:15 am
 Muke
+1 Skip Dr
Posted : 03/08/2013 9:20 am
Yup, skip dr.
Posted : 03/08/2013 9:21 am
Dont skip it ,,,, reuse
Hang used CDs in the garden over your vege plot to scare the birds
Posted : 03/08/2013 9:26 am
I have had luck rubbing radially with toothpaste and a lint-free cloth. Polish lightly with a dry cloth after to get the very fine scratches out, but they are tolerated more that you might expect.
EDIT: Or FLAC import with iTunes and Error Correction turned on, then burn another copy at a slow speed [IIRC High speed data burning can sometimes not conform to AudioCD spec]
Posted : 03/08/2013 9:46 am
Silver polish in small light circles over the full disc. Brasso is more aggressive so be careful if using that.
Posted : 03/08/2013 11:04 am
Do not polish in circles unless you never want it to work again.
... is the correct answer.
Posted : 03/08/2013 11:13 am
Very mild car polish.
Posted : 03/08/2013 11:51 am
Our Shaun the Sheep DVDs are ridiculously scratched all over, it's amazing they play at all. I don't think doing it by hand is going to be viable, it's a 6 CD box set... I was considering using a large piece of 800 grit (apparently that's what's in the skip doctor) and lapping it on a flat surface.
Posted : 03/08/2013 12:02 pm
You may notice small circles around the disc
Posted : 03/08/2013 12:03 pm
Ah, it's on the Internet so it must be right.
The way error checking works on optical discs, they can tolerate radial scratches (the odd missed bit doesn't matter as the ECC code will be along shortly). Scratches 'with the grain' as the data flows past the the laser can destroy enough data within a block to make it unreadable.
EDIT: Just skimmed the video. Whether cleaning the disc with his lunch has merit or not I couldn't say, but the way he's wiping it carries a pretty high risk of causing further damage to it.
Posted : 03/08/2013 2:23 pm
I have done this on loads of DVD's (used to be a member of LoveFilm, I'd copy the disc's and return them ASAP...half their disks would not copy as they were scratched). I used an old t-shirt and Brasso. You have to use a fair bit of force on badly scratched disks (i.e. 20mins worth of fairly hard effort), but I think I only had one disk I could sort.
Interestingly (ok, not really) , towards the end, quite a few disks came where other people had done the same (the surface of the disk looks matt, not shiny).
Posted : 03/08/2013 4:20 pm
I have no idea why that guy in the video does that. He seems to be of the school of thought that thinks that baking soda, coke and toothpaste etc can solve any problem.
Posted : 03/08/2013 4:29 pm
I've used Brasso on CD's in the past, which works well because the abrasive is very fine. Silvo would work, too.
As Cougar says, radial polishing is the key, I've had a CD wrecked after a fault in someone else's player put a radial scratch right round the disc. 🙁
Impossible to polish out effectively.
Posted : 03/08/2013 4:55 pm
Just remembered: after you polish the disc you need to wash the brasso etc off. But if after that you smudge the tiniest smear of light oil over the scratched area you might find it smooths the surface out indicated by increased shininess.
Don't get it around the center hole [may get in CDP], but you may find that means you can then hear/rip the disc 🙂
Posted : 03/08/2013 6:57 pm
young woods and his mates take scratched xbox/ps3 games to the local computer game shop cost them a £1 works most of the time
Posted : 03/08/2013 8:12 pm
