Any reason why I sh...
[Closed] Any reason why I shouldnt buy a 160000 mile VW Passat 1.9Tdi S 130?
I'm randomly looking for a Passat to replace our existing one which has a similar mileage. Our old one has been thrashed mercilessly with minimal servicing over 45000 miles. Its current mileage is 166000. It too is a 1.9tdi but only 115bhp.
Are there any issues I should look out for on the 130bhp model. Thinking of something 2004/5 before the 2.0Tdi models came in.
Posted : 28/01/2014 5:21 pm
May I be the first to reference DPF and EGR's from the other thread 😀
Posted : 28/01/2014 5:23 pm
Watches with interest... currently looking at spending upto 4k on a mondeo/passat sized estate. Some of the mileages are making my eyes water. I've just scrapped a 15 year old primera with less miles that we owned for 13 years. 😯
Posted : 28/01/2014 5:24 pm
I've got the same engine in my Ibiza and it's been great.
If you are fussed, check whether the air con compressor is working. Mine went around 160k and was £500 fitted for a new one - although the dealer wanted £850 just for the parts!
People keep banging on about DMFs, but mine is on a whisker shy of 230k on it's original clutch and flywheel. But, the engine has an easy life really, as the Ibiza is quite a bit smaller than the Passat, so presumable less stressed; especially if the estate gets used for it's carrying capacity frequently.
Friend of mine had the A4 with the 1.9TDi - think it was an X reg. He gave up servicing it and just used to top the oil up (not change it, top it up) every month or two. It ran and ran. He was waiting for it to keel over so he could have an excuse to get a new one, but it never did. In the end he traded it in.
Posted : 28/01/2014 5:26 pm
VanMan - Member
Not sure the 1.9 would come with DPF. I've not had any issue wit the EGR valve.
Posted : 28/01/2014 5:27 pm
its a big wallowy bus of a car that makes me feel like an old man.
other than that its great.
Posted : 28/01/2014 5:28 pm
Good service history and has it had a new clutch and dmf?
It's pot luck with any 2nd hand car.
Posted : 28/01/2014 5:30 pm
 LHS
Took a 2001 Passat TDi 130 from 105,000 to 235,000 miles with pretty much no issues at all. Had an interim issue with a MAF sensor which in the end cost £60 to fix and that was about it. With servicing, tyres, pads and discs I think I spent less than £2000 on it over 125000 miles.
My only word of warning was that i bought mine off a known source, regularly serviced ex-company car. It had been maintained money no object. If it hadn't been, i am not sure it would have been as trouble free.
No DPF on that engine. Mine did 235,000 on original clutch, turbo, egr valve etc. No sign of weakness.
Posted : 28/01/2014 5:34 pm
We changed the timing belt and radiator when we bought ours, I think I've only changed the oil once when the sump cracked after hitting a sleeping policeman.
The last repair was a rear wheel bearing which was straightforward. The engine mysteriously cut out today with all the lights on the dash coming on, then wouldn't restart. The AA guy jump started it and it ran and restarted fine thereafter. So maybe its time to get rid.
My only word of warning was that i bought mine of a known source, regularly serviced ex-company car. It had been maintained money no object. If it hadn't been, i am not sure it would have been as trouble free.
The one I have my eye on has a full dealer service history.
Check for damp in the passenger footwell - my 2005 estate started to leak and I couldn't find how to fix it.
Posted : 28/01/2014 5:37 pm
This. It's an engine-out job to replace hence the labour is also astronomical. At last count we had the compressors fail in my Golf, my wife's Golf, my brother-in-law's Passat and my father-in-law's A3, all at about the 4 year mark.
Posted : 28/01/2014 5:49 pm
Clutch judder was an issue on mine (they have a tendancy to do that IIRC), and it devoured front tyres. Also the AM waveband went AWOL so no 5Live, but apart from that it was okay... big and dull, and much better than the shitty 140ps new shape Passat that replaced it, on which the dash would regularly light up like a bloody kiddies' disco.
Posted : 28/01/2014 5:54 pm
I have done 100,000 in Passat Tdi's.
First on , same as yours 100bhp 235k - 312k . NO drama at all , no clutch issues or EGR problems. All I did was change the oil with a flush every 12k. and the air filter every other. Lots of tyres , 1 new rear caliper that was seized fully wound out .
Newer one 186k - 199k so far and is a 130 6 speed. Small issue with not being able to find reverse without some dicking around , ie put it into 3rd , bite clutch then go for reverse.
Not as economical by about 6mpg i reckon , even with the 6 speed.
Damp in the footwell normally battery tray related issue with drain holes.
Mine has parking sensors , cruise, variable radio volume, dimming mirror, traction control. All works as it should. I paid £1300 for mine its a 52 plate in inky blue , estate of course.
They are well made and some low milage B5.5 are on Ebay for more cash than higher milage B6 new shape ones.
A Passat you say? Weren't you recently considering a Unimog?
You've changed, man...
Posted : 28/01/2014 5:55 pm
The drains in the battery/plenum shelf get blocked with leaves/soil, then the collected water seeps in/over the bulkhead seals and floods the cabin. Also, the seal around the pollen filter (next to the battery above N/S footwell) degrades from collected leaves/soil, allowing water to run from the windscreen and gutters straight down the climate-control air intake and into the footwell.
I fixed the battery issue a couple of years ago, but the pollen filter seal went on me last weekend and left an inch or two of water. Luckily, no damage was done to the electrics and VW have given me new seals for free. Shouldn't have happened in the first place, but at least they're still looking after old cars - mine's a 2000.
Posted : 28/01/2014 6:03 pm
My old B6 PD was fairly crude, smokey and noisy and the cabin rather plasticky, and the rear tyres wore badly on their inside edges with a sawtooth pattern and lots of thrumming noise. I complained to VW about the tyres and got nowhere but a couple of months later someone from VW UK phoned me and asked for a copy of the photo I'd taken of the sawtooth wear, so they must have been concerned.
The new B7 Tdi is considerably quieter and smoother and is chewing front tyres much faster - about 17,000 miles a pair as opposed to 25,000 miles on the B6. The rear tyres seem to be wearing more evenly and someone has just told me that VW have rearranged the rear suspension to prevent the rear wheels canting inwards at the tops. I can easily get 62 mpg with the new B7 on a gentle A road run.
Posted : 28/01/2014 6:08 pm
Hangs head in shame. The Mog would have been a plaything, we just need a durable runabout for day to day stuff.
Posted : 28/01/2014 6:11 pm
Had my golf estate 130 6 speed for almost a year
Got it with 140000 now about 150000 and it's had a rear caliper
Rear pads shocks all round ( to many hay bails may not have helped )
The dmf is rattling more and more and now it's got some intermittent abs issue
Was full history etc just way it is with second hand cars
But feels good to drive still all the stuff still works air con cruise etc
Only average 42 but lots of small trips
Oh and erg can leak oil but does not seem to matter
Just had one from a garage as a replacement vehicle when my truck was getting sorted out, 380,000 on the clock! Was running perfectly.
Posted : 28/01/2014 6:13 pm
That's the old shape one then, B5 or B5.5 the facelift version. That engine is famously reliable and the car is decent. The passenger footwell water issue is caused by blocked drains under the battery, google for it. A 2 min job but if unattended leads to the demise of the comfort ecu.
Posted : 28/01/2014 6:20 pm
[b]ratherbeintobago - Member[/b]
[b]This. It's an engine-out job to replace hence the labour is also astronomical. At last count we had the compressors fail in my Golf, my wife's Golf, my brother-in-law's Passat and my father-in-law's A3, all at about the 4 year mark.[/b]
It's not an engine out job - at least not on the Ibiza and that engine bay is packed out like a tin of sardines with that engine in.
Like I say, mine was £500 fitted and the cheapest place I could find just a compressor for online was about £350, so I was quite pleased at how reasonable it was.
Posted : 28/01/2014 6:21 pm
 IanW
Mines on 188,000 now.
Clutch@50,000 (under warranty dealer).
Cambelt@120,000(£500 local garage)
Turbo@160,000(£700 did it myself)
Discs and wheel bearings@170,000(£150 did em myself)
Its also had a few steering arms here and there. Im the second owner picked with a full dealer history.
The car is now being driven by almost ex missus, still wont die or do less than 50mpg.
Posted : 28/01/2014 6:26 pm
 IanW
I was in it recently and thought the aircon was sounding a little noisy, which doesnt bode well given the above post.
Posted : 28/01/2014 6:30 pm
Three words...
[b]Electric Parking Brake[/b]
Mine was a nightmare to begin with, failing at junctions and leaving you stuck! Had to disconnect the battery to get it to reset (still keep a terminal sized socket in the glove box).
In the end it cost nigh on £1,100.00 to sort and IIRC that only replaced one rear caliper.
Other than that fault free motoring on a 55 plate 1.9tdi 🙂
Posted : 28/01/2014 6:46 pm
I got rid of my 2001 one after 12 years. I did really like the car even if it corners like a bus. I had the following issues as the car got older:
-Front suspension arms changed every 18 months.
-Head gasket at 120k miles.
-turbo boost sensor
-front springs
-injector wiring
-flooding from the usual blocked holes (holes are hidden and out of
reach. Rotted through the brake servo which allowed the water to get
sucked into the engine sump (might have caused the headgasket to go?)
-electric window cable snapped.
Bought a Mazda 6 in the end; come out much better in reliability surveys!
Posted : 28/01/2014 7:01 pm
Three words...
Not on the B5s afaik. And on the B6 the caliper motor, whilst expensive at about £230, is nowhere near £1,100! And apparently from I think 2008 on they changed the design to be better. Sounds like you need a better garage, suspension arms every 18 months implies some other undiagnosed issue.
Posted : 28/01/2014 7:06 pm
I have exactly that car. with 163k on the clock.
just passed it's MOT with no problems. 40mpg round town, 55 on a run. pretty quick, quiet, refined. big.
best car I've ever had.
Posted : 28/01/2014 7:18 pm
FWIW, i'll be selling mine within a month or so.
135K miles, black, 130bhp TDI B5.5 Version, fair condition inside & out and drives/goes well. Had a few niggles sorted in the last few months, probably go through its next MOT with no problem.
Just too big for us & prefer hatchbacks. We'd only want £1.3k, based in Somerset.
Posted : 28/01/2014 8:14 pm
I've emailed you.
Posted : 28/01/2014 8:55 pm
Well I can recommend buying a well service VAG product with 166000 miles. I flew down to Exeter this morning and just the Passat, it felt like a car with half the miles.
Exeter to Fife with still 150 miles left in the tank. Modern diesels are awesome.
The previous owner was a Doctor and had serviced it meticulously.
Posted : 03/02/2014 10:18 pm
looks tidy, how much was it?
Posted : 03/02/2014 10:38 pm
A nice looking car, hope it continues to give good service.
Posted : 03/02/2014 10:49 pm
£1900. It has a history file as thick as a phone book.
Posted : 03/02/2014 10:58 pm
Mr McMoonter, if I had known I would have taxied you in a similar Passat to your new car and stocked you up with a decent mug of coffee for your big journey.
Bought mine new, well a garage registered one with 800 miles on the clock in 2003. It was supposed to do 3 years as mine car and then become the family/wife's car. However 11 years later I am unwilling to let it go.
Up to 90k I just replaced pads and wiper blades and the cam belt, then front discs at 90k. It now now has 145 and was about to sell it again but my son said he would like it in a year or two so even though it goes well it was getting a little tired (looks great) so we thought a re-fresh would help. So new discs, same on the back, 312s now on the front, new struts and springs (went for B12s - same height and stiffness but better damping and not much more than org Vw) new intercooler, egr valve and ever important cam belt. We bought all the parts, all OE kit (but B12s), if you shop around it can be bought upto 50% off. Only giving this list as I reckon most this mileage will be tired in those areas. Told turbo and clutch can go from around this mileage but can also last to 200k plus.
Ours has a new lease of life, doesn't wallow, corners damn flat but Sports are low and you have to be carefully around speed bumps. Goes surprisingly quick, (quicker than a friends A6 V6 tdi) I think a lot of the 130s, especially if the cooler, pipe work and egr valve are good, put out a touch more than 130 - and all around 50mpg if keeping progress and no worse than 42 if rapid.
Pretty amazing around cars !
Posted : 03/02/2014 11:42 pm
That sounds like our Galaxy. 😕
Posted : 04/02/2014 1:19 am
Three words...
I only ever had two issues with mine. One was the price of the oil, could only be sourced from a VAG dealer and was something mental like £20/litre, the other was the parking brake occasionally failing to release. It once did it as I was at the front of the queue trying to disembark a ferry from Ireland; if you were behind me that day, I'm very sorry.
Couldn't tell you what revision it was, would've been something like 2005-6 vintage.
Posted : 04/02/2014 9:34 am
Google would suggest I had a B6.
Posted : 04/02/2014 9:42 am
 hora
mcmoonter very interested to see how you get on. I've always liked that era of Passat but 'scared' of them at high mileage.
Posted : 04/02/2014 9:43 am
Dunno about this oil issue. Yes you do need a special oil for PD engines, and you also need long life oil IF you have the car set to long life service schedule, but you can buy it in Halfords. It's not that expensive either, no more so than any of their other premium oils.
Posted : 04/02/2014 10:01 am
Hora, I drove the 500 miles from Exeter to Fife in seven hours. The engine was super torquey, no rattles or squeaks. It cornered well and the brakes were good. The fuel economy is very good. General build quality on what is a family car is super strong. It had been vacuumed but the interior looked as good as new. It had been well looked after, I've got a history file as thick as a phone book.
I bought it for my folks for plant gathering duties, but Im on the look out for another for when the mothership dies.
From what I've read on here the 1.9tdi seems capable of many more miles. Why you would need to spend more on a car I don't know?
Posted : 04/02/2014 10:42 am
Ive got an 05 plate 130tdi as a company car. It is literally bombproof.
Its done 205000 and the engine still feels like new.
only gripes are 2 heater matrix's, tiwce the drivers window motor has packed up, 3 CV joints, 1 clutch. Other than that... brilliant car.
Posted : 04/02/2014 1:00 pm
My sister has one of these cars, older though - W reg perhaps? Something like 120k miles. She said that water was getting into the car, so I told her about the 10 minute fix with the plenum drains, and she won't do it because it's 'not worth it, the car's on its last legs anyway'. In actual fact, two electric window motors have failed and the central locking doesn't work.
I told her that it will eventually destroy the comfort ECU which is expensive to replace, and she just doesn't care. She is going to let a perfectly sound car go to scrap for the sake of 10 mins work on it and zero cost.
Posted : 04/02/2014 1:04 pm
mcmoonter - Member
Well, mine will be on 230k miles by the end of the week; still on it's original clutch, DMF, exhaust, turbo....
That's in an Ibiza. Had it over 7 years and bought it 3 years old with 24k miles on it, so have put 206k miles on it myself.
It's only on it's 2nd set of front discs and pads - first set lasted 119k miles!!
Posted : 04/02/2014 1:37 pm
McMoonter, i have the 2007 version of your car, 150,000 miles on the clock. Absolute cracker of a car. I have a massive dent in the rear door and the alloys are falling apart which i am going to repair as i do not want to get rid of it and they are annoying me. I will probably run it until it dies. I have had it for 4 years and it has never missed a beat.
Posted : 04/02/2014 1:50 pm
based on your record with ECU's, i'd ignore you as well....
Posted : 04/02/2014 2:05 pm
I missed this thread before. I have just this weekend sold my Audi A4 TDi 130bhp which I really loved, with "just" 98,000 on the clock. The engine was superb, beautifully smooth, and the rest of the car had only needed two springs, a suspension arm and two sensors in 50,000 miles and 6 years. Amazing to me.
Its replacement - a 1.9 TDi 115bhp - is much lower mileage but really doesn't have the grunt at all. It feels like 0-60 in a half a day after the old one and seems to use fuel like it's going out of fashion, so maybe off to have it re-mapped. I'm pretty sure I haven't got a binding brake anywhere.
Posted : 04/02/2014 2:55 pm
If its the 130 PD engine, I have an interesting and informative VW technician training pdf, 50 or so pages, that goes into a lot of detail about the main engine ECU, its sensors, their functions, and the various actuators. Its actually (risks flame) a fairly simple engine, when you get down to it, thats light on sensors compared to a CR engine, has no DPF, and can run happily without an EGR.
I'll find your email address and email it to you.
Posted : 04/02/2014 2:58 pm
****ing ha ha.
I'm right though.
Posted : 04/02/2014 3:15 pm
Agree with the stellar miles / no hassle... had the 1.9 tdi engine in an A3 130 sport tdi quattro (brilliant car when remapped), a Fabia VRs (also remapped) and now a Touran...
No dpf, no mass of sensors, just a boring ordinary cat.
Place I worked had the 130 Passats and they all had over 300k on them despite being driven by everyone...
Posted : 04/02/2014 3:21 pm
 hora
What year(s) was the 'good' 1.9TDI engine?
Posted : 04/02/2014 3:22 pm
I think it's good all the way. It was replaced by 2.0 and 1.6 afaik, not sure though. In Passats, they brought the 2.0 in with the B6 Passat in 2005, although to be honest as long as it's had the oil pump and innjector recalls, it should be pretty good too. No DPF on the early ones.
Posted : 04/02/2014 3:32 pm
Hora- any of the 4 cylinder pre common-rail ones should be decent, but there seems to be agreement that the PD ("Pumpe Duse") ones are the ones to have.
I've had cars with this engine and would agree- its fairly simple, pretty economical, good power output, and all its foibles are well-known and usually not that dear to fix.
I think the PDs kicked in about 2000 or so.
Posted : 04/02/2014 3:35 pm
(Based on my thread a couple of weeks back, where I may or may not have been getting scammed after selling a Golf with the new 1.6TDI CR engine, I'd love something with a PD engine if they still made them...)
Posted : 04/02/2014 3:37 pm
Think the 1.9 went out on plates 02 and 03 as my A3 was a runout before the 2.0 facelifted car came in.
This engine did a load of applicationds from static power source and marine as well as car...
Its all on Wiki but its a long read.
http://en.wikipedia.org/wiki/List_of_Volkswagen_Group_diesel_engines
Posted : 04/02/2014 3:38 pm
Maybe in Audi land. The VAG brands run different engine lines at different times. I test drove a 57 plate Seat Altea which had a 2.0 TDI but with the old style injectors ie not piezo controlled. It was very obvious from the drive.
Posted : 04/02/2014 3:39 pm
Ignore long life service intervals on anything with a turbo, use a decent semi synthetic and change oil and filter every 6000 miles or so.
I looked at the Passats the last time I was buying a car (2005 😯 ). I think the 2004 ish model was the one to go for, reliability wise. I bought a 406 HDi estate instead, and still use it daily. Best car I've owned and cost no more than the usual service/wear items.
Posted : 04/02/2014 4:16 pm
Flicker- PD all need fully-synthetic.
Posted : 04/02/2014 4:33 pm
Well I've just bought a 1.9 TDi Audi and it's a 2007 so they were still going as recently as then.
At just 7 years old probably the newest car I've ever had.
There are lots of horror stories around about the 2.0 TDi oil pump shaft breaking - so I avoided them.
Rickmeister - where did you get your re-map done?
Posted : 04/02/2014 4:39 pm
Do you work in Afghanistan?
Posted : 04/02/2014 4:49 pm
codybrennan - Member
Do they? fair enough, drop the oil at half intervals still, your turbo will love you for it 😀
Posted : 04/02/2014 4:59 pm
ononeorange - Member
It doesn't so much break as the hole in the pump wears out, the shaft spins as usual and the pump, well, doesn't. Very poor design on the early 2.0l models, which has since been fixed.
Posted : 04/02/2014 5:02 pm
No - use oil that conforms to the VW spec - not just ANY old semi synth.
Re the oil pumps - it was a certain batch from a certain factory in a certain period that had the issue, not a recurring fault across the range. It was identified pretty early on and subjected to a recall for the affected cars. You've got zero chance of it happening to you now, cos all affected cars will either have died or been fixed.
Posted : 04/02/2014 6:48 pm
The early 2.0 balance shaft problem is a killer. My mate bought a 55 plate Passat 2.0 tdi in 2011 and it lasted about 8 months before the oil pump shaft went and seized the engine.
It was an ex Leaseplan car and, if there was a recall, it was missed. It cost a couple of grand to fix and, at the time in 2012, the modified oil pump was on back order with no delivery date available.
My mate found a guy who did the marine engines and he did a nifty mod to the oil pump or something and it's been fine since.
Posted : 04/02/2014 7:06 pm
Ouch.. moral is - check the recalls when you buy a car...
Posted : 04/02/2014 7:11 pm
FFS 😀
I'll rephrase my earlier statement to "use the manufacturers recommended oil" which I'd assume most would. Surprised an engine of that vintage would need fully synth, poor design I guess 😉
The point I was trying to make was to ignore the long life service intervals, they aren't good for your turbo.... …...
Posted : 04/02/2014 7:47 pm
VW 505 01 or 505 02 fully synth for PD engines.
2001 My Passats or Y reg for the B5.5 100bhp or 130 bhp variants. Were fitted all the way through the B5.5 and in the fisrt 2005 55plated B6 models.
100Bhp models on got 5 speed box, optional 6 speed on the 130's.
Posted : 04/02/2014 7:56 pm
No, the camshaft activated unit injector design requires extra lubrication qualities of the oil.
Why? The manufacturer recommends it after all. Long life servicing uses a comination of engine revs and oil temperature to assess the load on the oil - the idea being that if you are doing lots of long journeys the oil doesn't really need changing as often as if you are doing lots of short ones.
Posted : 04/02/2014 8:18 pm
Lots of bad press out there on the vw forums both with pd engines and the more modern petrol and diesel ones
About long life service causing issues.
For me I'm not taking the chance oil change evey year is easy to do
So why not.
Halfords sell oil that meets modern vw pd requirements so easy to get
Posted : 04/02/2014 9:10 pm
I would guess that 99.9% of Volkswagen owners don't frequent VW forums.
Posted : 04/02/2014 9:12 pm
Huh.. I was doing almost entirely motorway miles so thought long life would be ideal. Doing more than 10k miles a year too!
Posted : 04/02/2014 9:13 pm
Tbh I'd not looked into it until it came up as a possible
Issue with 3.2 petrols and cam chain stretching.
But then we should not believe all things on forums
Just for me I will stick to yearly. It's cost me a about 80
For all the filters and branded oil to vw 507 spec for pd
Engines
Posted : 04/02/2014 9:18 pm
I mainly went to long life because at 10k intervals I'd have been servicing every six months. Annoying.
Posted : 04/02/2014 10:52 pm
With regard to service interval, I would do whatever you are comfortable with.
Service interval on my Ibiza is 10k miles, but I've drawn it out to 15k miles as most of my journeys are dual carriageway/motorway cruising.
Done that from 140k or so, perhaps before, and it doesn't seem to have affected anything in the 90k miles since.
Posted : 04/02/2014 11:50 pm
Picking up a 55 plate b6 1.9 tdi on thursday. Not had an estate for a while. It's got 118,000 miles with full service and just had belts, water pump clutch and flywheel. At 105 bhp I might just get it remapped.
Posted : 05/02/2014 9:36 am
1.9tdi 130 in a 2002 a A4 here. 220000 on original clutch, flywheel, exhaust etc. No dpf. I had it on long life servicing up to 160k and now do it every 10k. It used to use 1/2 litre of oil in 20k but now its on 10k it never needs topping up. Other than servicing the only problems have been a failed air con compressor (I got the garage to leave the belt off and I put up with a hot car in august) and it has a bit of an appetite for offside headlight bulbs which are a ballache to replace and it chews the inside edge of tyres. 50mpg easy, more if I'm careful. Easily fast enough. Engine is a bit noisey by modern standards but it doesn't smoke and sounds quite nice from the cabin if your pushing on. Hard to imagine a cheaper car to run over its life.
Posted : 05/02/2014 11:36 am
petrieboy - Member
That reads just like my experience with my Ibiza. Good to know there's someone else with the 130 engine still on it's original bits. No one believes that mine is on original clutch and exhaust.
Mine doesn't need topping up between services though - although I should probably start doing more regular dip stick checking, than I currently do.
My air con compressor went at around 140k miles. The local independent I use for all servicing also does air-con stuff so replaced it for £500 fitted. At the time I was doing 32k miles/yr so figured £500 was a small price to pay for the comfort, given the hours I was sat in the car.
Mine used to blow headlight bulbs like nobody's business, but last time one went I swapped to Halfords heavy duty ones (dark green blister pack) and they are lasting a lot better (touch wood!). Perhaps give them a try.
Posted : 05/02/2014 12:28 pm
03 Audi A4 1.9tdi here on 150,000 miles only things that have gone have been wiper motors on front and rear. Servicing every 10k or so but like others I'm mainly driving on main roads at 80-100kph to work.
Offside headlight bulbs used to go all the time but noticed that the plastic clamp between the headlight cluster and the chassis had sheared so the light was vibrating a lot - common enough apparently and got replacement clamp things off eBay and been perfect since.
Posted : 05/02/2014 3:50 pm
What are the long-term owners of these PD engines doing for cambelt changes? I'm seeing mixed stuff on the web- is it every 4 years?
Posted : 05/02/2014 4:10 pm
Ononeorange, remaps..
I have had three maps done on different VAG cars. Al have been excellent, done bigish milages and never missed a beat. Each forum seems to have its favorites though each supplier will do the Vag group.
A3 1.9 130 Sport Quattro. Superchips map. 130 bhp to 170 ish and a good torque increase. 120k miles done by me. I wish I had never sold this car..
Fabia 1.9 Tdi Vrs. Shark remap (Skoda forum favorite) from a local to Edinburgh agent. Same engine as above, same gains. 90Kmiles
T5 175 SWB Kombi. Pendle Performance (T5 forum favorites)in Barnoswaldwick (where Hope are). 175 to 220 bhp and a great torque gain. Included a dpf delete, 1st in country for this. What a van.. loved this too
I always mapped them early, inside 5k miles so probably not really run in. All never failed, no slipping clutches or big oil consumption. Very reliable and all on long life variable oil changes and all serviced by independents from new, never VW.
Now driving a 2006 105bhp Touran, in grey. It feels like my life has ended but it does have the non dpf, simple cat only and not festooned with sensors, 1.9tdi. Its just gone through 170 kilometers.. but its duller than a dull thing that has some extra dullness added to make it dull. Plus, it feels like it wil be dull for a long time.
But, they do sell 175 bhp 4motion VW Caddy Cross in Viper Green here...
Posted : 05/02/2014 4:11 pm
Main dealer told me every 4 years or 60k miles. £350.
However - it seems to vary a lot year on year. Some models are 40k some are 80k. I'd contact a dealer if I were you.
Posted : 05/02/2014 4:12 pm
