After breaking a unit in my conservatory have been quoted £340 supply & fit a new one. Size is 1690 X 870 with a slope on the top edge to follow the roof profile. Needs to be toughened.
Does this sound reasonable ?
Simon
well it doesn't sound cheap, I'd be having a shop around
is that just for the glass? we had a whole window and casement fitted for only slightly more than that!
Edit: and it was toughened glass as per building regs.
Sound tres expensive.
Commercial price would be approx £55/sqm +20% for the raked head for supply. However, as a 1 off domestic fitted, I think if you shop around, you should be able to save a fair whack on the £340.
Plenty of glaziers about. Any particular reason for toughened over laminated?
I am a double glazer and that price is well over the top imo. A curved unit would be less than that...
Where abouts are you located?
Seems quite a bit. I got 8 double glazed units replaced for £750 all different shapes and sizes. All these were replaced in a first floor flat for that. Get some more quotes, I found my local glaziers were way better value than the big boys.
Thanks for the advice guys - looks like my shock was well founded!
Hi Tony - I'm in Kent, West Malling - see you are in Kent too. Can you help with a quote?
Simon
