Android GPS
[Closed] Android GPS
21 Users
What is the best Android GPS program?
Is there one that works without being connected to the internet for use in areas with a poor signal?
What price are most apps like that?
Thanks.
Posted : 27/11/2011 9:26 pm
navfree - no internet / data live link needed and, err, free
[url= http://android.modaco.com/topic/339211-navfree-for-android-released-at-last/ ]see here - note 2 different versions[/url]
Posted : 27/11/2011 9:28 pm
If you already use Memory Map, try MMtracker.
Posted : 27/11/2011 9:52 pm
 kevj
This. Excellent application and worth every penny.
Posted : 27/11/2011 10:02 pm
ah, just realised you may well mean offroad 😳
navfree needs 72mb internal memory! Blimey, never going to free up that much space on my Desire.
Uninstalled skobbler today. It left me in the dark on a roundabout once too often.
Posted : 27/11/2011 10:03 pm
shopper, you can put it on the SD card
(Ed) the app itself seems to be taking 84Kb on my phone - the maps and postcodes are big, mind !
Posted : 27/11/2011 10:05 pm
 cp
Another vote for mmtracker. Installed the free one to my desire s a couple of days ago and its brilliant. Will be upgrading to the full version. You need mm maps though.
Posted : 27/11/2011 10:27 pm
There have been a few threads on this and OruxMaps has been recommended a few times.
Im going to give it a try tomorrow, I have downloaded the OS maps for offline use and I'm just importing a couple of GPX routes to see how it goes.
Posted : 27/11/2011 10:37 pm
When you say GPS program, do you mean a Sat Nav type application, or a Sport Tracker/Route recorder type?
Posted : 27/11/2011 10:41 pm
A Sport Tracker/Route recorder. I have an older Memory Map program on my computer but I'm not sure if that will help with new applications.
Posted : 27/11/2011 10:48 pm
My Tracks / Endomondo / Runkeeper?
Posted : 27/11/2011 11:18 pm
Viewranger, works on multiple platforms, also has the buddy beacon as a handy safety feature.
http://www.viewranger.com/
Posted : 27/11/2011 11:43 pm
I've tested Endomondo today on a walk (often under tree cover). The result was pretty good. A few friends have complained about Endomondo giving some wild data, but viewing the map of our walk today online, it looked pretty accurate. The downside was that the battery was drained within 3 hours, but that was with continued updating to the website, battery might last longer if I'd turned that off, not sure tho, it's all a bit new to me.
Posted : 27/11/2011 11:55 pm
I Like Viewranger.
APF
Posted : 28/11/2011 12:18 am
I use noom, with the cardiotrainer module thingy. Tis pretty good, though it was very cloudy and rainey last run and it did drop out a few times, generally it's pretty accurate though...
Posted : 28/11/2011 12:27 am
I use everytrail pro as it allows you to download osm maps to the phone so you don't need network signal. pretty accurate too (desire s)
Posted : 28/11/2011 7:04 am
Top tip, if you use a route tracker, turn the data off and your battery life will be much better. i use mytracks and it seems fine.
Posted : 28/11/2011 7:46 am
RMaps is very good.
if you browse to the area you'll be going to when on wifi it caches the map so its there for you when the signal 'int ...
Posted : 28/11/2011 9:03 am
If all you're doing is recording, forget maps.
Posted : 28/11/2011 9:11 am
What do you want it for?
If you just want something that will record where you have been without necessarily using it as a navigation aid - I would give My Tracks a try. I have never had problems with it losing gps lock, unlike other apps I have tried.
The Google Maps application will let you cache a certain area of map centred on where you search for, which can be quite helpful as a back-up. I don't know whether My Tracks would automatically be able to access this cached map info, or whether you can only see it using Google Maps.
If you are after a sat nav program, then I would use Google Nav - seems to work really well, although I have had occasion where it completely loses GPS lock with a clear sky & fails to regain it. Very rarely does this happen though.
I have recently discovered the Traffic View layer and it seems very helpful.
Posted : 28/11/2011 9:47 am
Memory Map have launched their Beta version for Android recently. I bought the memorymap package a few years ago for a PDA, so I can now use those. Will be trying MMtracker as well though, after reading this thread.
Posted : 08/12/2011 11:12 am
I like Rmaps as it has OS maps in there, although I struggled to work out how to import & use a gpx file with it successfully.
Posted : 08/12/2011 8:50 pm
MM tracker allows you to youse any laicense version of the MM maps. I have the whole of the UK on the earlier license for MM but when I got a Vista PC I had to use the newer version of the programme which wouldn't use those maps. Meant I had to buy again. MMTracker doesn't care, so I get to use them all.
Posted : 08/12/2011 9:23 pm
If its for Sat Nav purposes then I'm currently using Sygik,works just like Traditional Sat Nav so doesn't need data connection just GPS.
Posted : 09/12/2011 8:45 pm
