In my work Outlook I have two mailboxes; my personal one and an "Team X Enquiries" one, which is a team mailbox. However if I reply to a mail in the team mailbox, although it appears that it is sent from "Team X Enquiries", the actual sent mail is saved in my personal 'Sent' folder, not the 'Sent' folder in the team mailbox.
Any way I can change this so it saves in the 'Sent' folder in the team mailbox?
Yes, there's a script your admin can run. Hang on...
Edit: Scratch that, you need to add the mailbox as an account whereas you've probably added it as a mailbox. First remove it in it's current form, then go to File > Add account, enter just the email address of "Team X" and Next... Only if you have the right level of access will it work, though.
Yeah, I don't. I didn't even have access to add it as a mailbox, that was a helpdesk/admin job.
I've found an option when sending a mail to "save Sent mail in...", so I'll just have to remember to do that every time.
Can you create a rule to move the item from your 'sent folder' if it's come from a certain address?
Ah, yeah, maybe, I'll have a look at that
As StuF says, create a rule.
As above, it's a backend setting to have sent items go into the shared mailbox sent items, not the users. Can be done on a shared mailbox, no issues. Saving to the user's sent items is the default setting. I'd put a request into your servicedesk to ask for that to be changed In the short term, set up a rule.
