Air tight tape and ...
Air tight tape and compriband
4 Users
are these the same thing or should  you have both on a window installation?
Posted : 12/12/2023 11:34 am
I think they are different things. My dad used to run the uk arm/distribution for Compriabnd/Illbruck so would probably know a lot more than me but he seems to be incommunicado (ie out Christmas shopping) at the moment.
Posted : 12/12/2023 1:14 pm
Compriband = 'foam' strip to fill gaps springily and flexibly between different materials such as window frame and wood or brick.
Air tight tape - used as specified or designed to seal gaps, usually between either a flexible sheet barrier or larger rigid boards such as OSB. Can also be used between window and wall/other material, but be careful as to how flexible/stretchy it is.
Has this been specified or are you making your own decisions?
Posted : 12/12/2023 1:21 pm
Making my own decisions.. which could be unwise!
Posted : 12/12/2023 2:19 pm
 Haze
Compriband (or silicone) as external seal.
Air seal to the internal side (linked to VCL)
Posted : 12/12/2023 3:39 pm
