Advice on TV signal...
[Closed] Advice on TV signal boosters please...!
3 Users
 DrP
Our arial enters the loft, then is split to 4 locations in the house. As such, the signal is chuff.
In the lounge I've popped a simple booster there, but ideally i'd like to boos closer to the source.
Is anyone here a TV whizz, and can reccommend a decent 4 way booster/splitter please?
Cheers,
DrP
Posted : 17/08/2009 11:21 am
How is the cable split at the moment? Is it split using a proper box? Or is the cable just split out to the 4 different locations?
Depending on how it's done, you might find you don't need a booster at all, and that just having a proper splitter makes everything work better. Something like [url= http://www.maplin.co.uk/Module.aspx?ModuleNo=29531 ]this[/url].
If it's using a proper splitter, and a booster is required, then just something like [url= http://www.maplin.co.uk/Module.aspx?ModuleNo=223502 ]this[/url] would be fine...
Posted : 17/08/2009 11:28 am
Screwfix do some that are fine for the job;
[url= http://www.screwfix.com/cats/A331868/Electrical-Supplies/TV-Range/Amplifiers-Distribution ]http://www.screwfix.com/cats/A331868/Electrical-Supplies/TV-Range/Amplifiers-Distribution[/url]
Posted : 17/08/2009 11:31 am
