Yo. I bought some "2K lacquer" off t'Bay.
There aren't 2 separate parts to aerosol that you unseal/mix before spraying, just a normal can. Seller is saying it's the above.
This is a pile of crock right?
Is there nothing on the can to release/activate like in this video at 36seconds-ish?
[img]
[/img]
[url= http://www.eastwood.com/paints/2k-aero-spray-paints.html ]http://www.eastwood.com/paints/2k-aero-spray-paints.html[/url]
Well it isn't 2k if you only have one part in the can. You can use 2k technology in a 1k system if you are careful. Polysiloxanes work as you keep them very dry and then package under nitrogen. You can do something similar with polyurethanes. Bit niche though, probably just an air drying single pack system.
Got a photo and anything on the chemical safety? That normally gives you a clue.
I've opened a return case.
